Question about Frigidaire GLTR1670A Front Load Washer
Very loud when spinning.....
My washer has gotten extremely loud when it is spinning out. It's so loud that we can't hear the t.v. two rooms away. What could be causing this? Has the bearing gone dry?
  • wire nut Nov 28, 2007
    very noisy when spinning ... sounds like a bearing gone bad.
    any ideas where to get a picture of how to take it apart
  • noisywasher Dec 13, 2007
    during last spin cycle washer is so loud you can hear it like it's going to take off...spinning like crazy....washer is not moving but the noise is unbelievable.....
  • 213 Answers
The rear bearing is bad. its a sealed bearing and cant be regreased. it has to be replaced. very difficult job
Posted on Nov 27, 2007
My whirlpool duet washer hammers very loud when it spins. The outside of the machine doesn't seem to vibrate much but it is very loud.
That is a common occurrence with dryers such as this one. Even though it sounds bad, it is harmless. If it really bothers, you can re-balance the load and it should reduce the vibration.
Jul 29, 2008 | Whirlpool Washing Machines
Squeaky basket and loud vibration when in spin cycle.
Bearings worn, belt loose and probably motor brushes.
May 17, 2012 | Kenmore HE3T Washer
Very loud rumbling noise during spinning
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Sep 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Vibration of wash machine
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary. If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Please do accept this solution and revert for further assistance.
May 22, 2009 | Danby Washing Machines
Tub makes loud thumping noise when spinning
Good morning! It's common to hear a loud thumping noise during spinning because the load (clothes) are not properly place in the tub. Please try to put the load in order & compress it down. best regards.
May 02, 2009 | Washing Machines
Mah3000 aww making extremely loud, clanking, grinding during spin
Gotta admit tonytools albeit not cheap has the best easiest tool to do that rough difficult repair.
Jan 01, 2009 | Maytag Neptune Washer
Kenmore Oasis Spin Cyle Extremely Loud
Your probably right as most washing machines use bearings and they do wear out rather quickly on some machines ,depending on how yours was put together will determine on how easy it is to change , some manufactures made it much more easy than others .If you remove the back panel (that's if it has one )and after it has gone through its spin cycle and you have turned of the power you should be able to feel around where the bearing is incased to see if it has generated an amount of heat even though they are usually encased in oil as this would be a indication that it has failed, if you watch the machine clicking into spin mode ( by looking at the motor etc with the back cover removed)you will also get a better idea as to what parts have come into play and pinpoint the problem area .
Aug 07, 2017 | Kenmore 27032
Very loud on spin cycle
yes ..bearing on upper side of gearcase has gone bad probably from a water leak from tub seal
Jul 20, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Frigidaire GLTR1670A Front Load Washer Logo
127 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
