Question about Acer Aspire 1642WLMi Notebook
Acer laptop booting only if battery removed and on main power
I have an acer aspire 1641 NWLMI laptop. All of a sudden it stopped loading windows xp. It comes to the desktop screen and then the mouse and the key board in the laptop does not respond or only the mouse responds with a great delay. But if i use a usb keyboard and mouse it works fine. The cpu keeps on running at 100% even when i am not running any programs. I check the task manager and it says that a process called 'system' is running constantly consuming 40-50% of processor usage. I was not able to shut down as the shut down window never appears after i press it. I was initially able to run the programs using the usb key board and mouse but after a few boot ups it stopped loading desktop.
I thought it is a virus and reinstalled windows xp. formatted the hard drive. While reinstalling i got stuck (laptop was not responding for a long time) while it was setting up network devices ( if i am not worong; i am sure it is something to do with the network). I powered it down using the button and restarted and this time it finished installation. But when i restarted the same problem came.
Next i installed ubuntu linux and this also did not install completely and i had to stop. Same problem comes (desktop appears and everything hangs);.
I rememebered that before shutting down the windows asked me that one process related to battery power was not responding and i used to give end now option.So i thought it is something to do with the battery so i removed it from the laptop and connectd to main and restarted . This time it is working fine !
What could be the problem ? I dont think the battery is alltogether gone because i am able to start and run the computer for sometime with the battery. Besides i dont understand why it does not load completely when battery is in the laptop with the main supply connected.
Can anyone help, please? -----
  • paulose Nov 27, 2007
    Excellent ! Everything is working fine ! Thank you so much 24 seven,
    I could not get the ACPI option from BIOS but i got it from control panel- system- hardware- device manager- batteries. I disabled the ACPI option as you suggested and restarted with the batteries on the laptop and it is working fine. It is running on batteries also. Only I am not seeing the battery icon warning how much time is left on the battery.
    So was it a purely software problem or some thing in the laptop has gone wrong ? Is there anyway i can know how much battery is left ? ( not that i am unhappy with the present situation )
  • paulose Nov 28, 2007
    Thanks again for taking the trouble to solve my problem. I had already rated your solution as 'fixya'. I thought that is the maximum marks ! Is there anything else i need to do rate it ? Please tell me.
Had the same exact problem, however, was only able to disable the ACPI in device manager while running without the battery plugged in. The system works well now. Thanks for the tip.
Posted on Feb 12, 2008
  • 883 Answers
Try disabling ACPI (Advanced Configuration Power Interface) in BIOS screen, if you have that option. Something does not agree with Windows control of all ACPI devices...could be the modem or ethernet network. Also, if no success, try disabling "allow this device to wake computer" for either (or both) the modem or ethernet network devices in control panel-system devices option screen.
Posted on Nov 26, 2007
  • Marty marty Nov 27, 2007
    when I said to "...try disabling ACPI", I meant to disable it in any way possible, although BIOS is usually the easiest way. On my PC, I can only see this option in BIOS. Anyway, I'm glad you're up and running but I do not have yet a solution for the new battery icon problem, but I'll work on it. In the meantime, can you rate my sol'n as "SOLVED"...thanks
  • Marty marty Nov 29, 2007
    No. thanks again for the rating...I had forgotten that fixya.com recently changed the names used for rating...a rating of "fixya" used to be called "solved".
My Acer Aspire 5101ANWLMI laptop stops all of sudden with or without battery. I want circuit too to knowwhere DCV stopped. Satisfy me with reasonable costi would buy second acer product
Hi there, As per your information i sueegst check the Motherboard Power supply connection or its called SMPS. replace the SMPS and i am sure your Laptop will start working again. If you found any sound after pressing the power button then the problem in RAM not in SMPS. Follow the few step below.
1. cjeck power connection in main board.
2. Check the green light in power adeptor its ON or
OFF.
3. check the voltage.
If all is fine then check those i mentioned in top lines. Thanks & waiting for your feedback.
Mar 17, 2010 | Acer Aspire 5101WLMi Notebook
Acer Aspire 7520 black screen wont boot
Turn off notebook. Remove the battery. Press Power button. Notebook should start working. Wait for 15 secs. If the screen still blank press Power button and hold it for approx. 4 seconds until notebook is powered off. Then press power button again. Bingo, problem should be solved.
Dec 19, 2009 | Acer Aspire 7520-5185 Laptop
Hello there, i have problems whether plugging the AC supply into my acer aspire 6920G laptop. when i plugging the AC, the laptop will suddenly shutdown, then boot up again. but when im using battery, it...
I am sure its totally fault of your OS. Becouse some when ac working well, some where battery. your OS does not recognised your power control properly. Try to use single OS and get batter result. if done thumbs me.
Dec 16, 2009 | Acer Aspire 6920 Notebook PC
Unlock a bios password on an acer aspire
Hello, I have an old Acer Aspire 3680, the problem is once i press the power button the screen is frozen displaying only the Acer logo, i cannot even go to the BIOS (pressing F2) to change my setting to boot from a CD. Please help. THX
Jul 31, 2009 | Acer Aspire 3680 Laptop
Laptop wont switch on fully
Did you press F8 as you boot up to get boot up options and did try the Last Known good Configuration and Safe Mode?
If these didn't work I suggest you re-install Windows.
Apr 10, 2009 | Acer Computers & Internet
Acer 1641 laptop keyboard doesnt work
we removed the battery and used only the AC. all works fine.
Nov 26, 2008 | Acer Aspire 1642WLMi Notebook
Graphic card for acer aspire 1641
HI Denis,
Unfortunately you cannot change the video card an your laptop, you see its built into the motherboard. There are some high end laptops that use a MXM? slotthat it is possible to change cards and even then its still iffy.
the only real hardware changes you can make to your laptop are the battery, the RAM, and the hardrive.
Nov 13, 2008 | Acer Computers & Internet
Acer Aspire 6920G keyboard and mouse stop working
yes use your laptop with the battery removed and use it only from the mains.
Oct 21, 2008 | Acer Aspire 5100 Notebook
Formatting of laptop
go to acer website and download what you need
http://global.acer.com/support/download.htm
good luck
Terry
Mar 31, 2008 | Dell Inspiron 6400 Notebook
Acer Aspire 5100
This is a duplicate posting, the main discussion can be found here: http://www.fixya.com/support/t133152-acer_aspire_5100
Feb 06, 2007 | Acer Aspire 3000 Notebook
Acer Aspire 1642WLMi Notebook Logo
459 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
