Question about Procom (CGL100MZ) Infra-Red Heater
Pro com infra-red heater
Flames come out at the bottom left of ceramic, not much but still scary.
  • 625 Answers
Check for a missing or burnt baffle
Posted on Dec 07, 2007
Pilot turns on and so will unit for about. 5 minutes...pilot flickers as if there were air blowing into it...any suggestions? It is. A Pro-com MD100TBA
the flame confirmation thermocouple might need looking at biased on your description , this item sits inside a stainless steel metal tube that's about 1.5 inches long an is someplace around the edge of the heater , this item confirms that the main flame has lit and shuts off the pilot most times too . this is why I believe it is not working
Jan 18, 2016 | Procom 10K BTU, Vent Free, 2 Plaque...
Heater runs but then dies out and smokes replaced fuel hoses is it the spark plug maybe
The spark ignition electrode is done doing its job as soon as flame is established. I'm thinking your infra-red eye is possibly the culprit. It 'sees' the infra-red given off by the flame to hold the fuel valve open. It is a glass eye that may not be perfectly aligned to 'see' the flame or it could have a dirty lens. Clean it first and try again. Try to make sure it is properly aligned to see the flame when it is established.
Jan 03, 2015 | Heating & Cooling
FLAME IS NOT A BRIGHT ORANGE AND EXTTENDS ABOVE GRATE
You should take the heater apart and blow it out. Wore brush the burner. and blow out the pilot assembly. Vacuum the bricks. Put it all back together. It just needs a little tlc.
Feb 05, 2011 | Vanguard International Infra Red - Large...
My flame is above the guard on the heater in the middle flame. How do I adjust the flame to be lower?
this is happening because the bricks need cleaning. I imagine the flame is burning blue instead of glowing red in the middle brick. Contact your local propane or natural gas dealer about getting the heater cleaned. This type of problem causes a huge loss of efficiency and could be dangerous.
Oct 29, 2010 | Vanguard International Infra Red - Medium...
Vanguard wall heater does not burn correctly
Hi the plates/burner needs cleaning out blowing then out with air line when off should help
Jan 26, 2010 | Vanguard International Infra Red - Medium...
The flame in weak and it heater will not light
You need to replace the ODS pilot assembly.A low pilot flame will not allow sufficient heat to generate proper voltage to hold valve
Nov 13, 2009 | Vanguard International Infra Red - Large...
1600c vanguard propane heater, big flame on middle grate
Make sure the grate is in the holder like the others, and nothing is blocking the bottom of it. They often slip back where the fire misses the inside where it should hit.
Dec 22, 2008 | Vanguard International Infra Red - Large...
Vanguard heater
Usually the pilot goes out because of a faulty flame sensor or wire connection.
Nov 30, 2007 | Vanguard International Infra Red - Large...
Procom (CGL100MZ) Infra-Red Heater Logo
57 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
