Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum
Problem for Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum
Change belt on a hoover tempo
By jekajk on Aug 04, 2009
How do you change the belt Have lost directions. Belt is broken so have no idea how it goes in after I buy a new one
Solution #1
posted on Oct 22, 2009
Not Rated)
ptomward1
Rank: Master
Rating: 100%, 1 votes
Remove the cover that covers the roller brush, (four screws) and remove
the roller brush and replace belt, it goes between the motor shaft and the roller brush. Replace the cover and that should do it.
Tom
Was this helpful?
Yes
No
Popular Solutions for Hoover F7425-900 SteamVac V2
Questions and Unsolved Problems for Hoover F7425-900 SteamVac V2
Do you recommend Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum?
Answer
Answer
where do I put the detergent, I mean in which container?
Answer
steam vac turms on and suction/ brushes works but no water/ cleaner is coming out
Answer
i have the hover steamvac spinscrub widepath model f7410900. works great but now the scrub brushes... (More)
Answer
2nd time I used Bissell Pro Dry carpet cleaner ; plugged it in, turned it on, water pours out the... (More)
Answer
Hoover Steamvac model F7425-9000: The shampoo bollte attached to the clean water reservoir became... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hoover F7425-900 SteamVac V2...:
Top Vacuum Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Vacuum Experts
Top Vacuum Repair
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
