Question about Akai PT5492S 54" Rear Projection Television
Akai rear projection has 3 colors blue green yellow.
How do i get these colors adjusted? I have shadows in these colors. thanks.
when i check the convergence, nothing happens when i adjust the blue.
  • 1 more comment
  • tjmort10 Nov 30, 2007
    thanks for your advise terryfic, i went to a local tv repair shop and he told me somthing about the green liquid was infected. is this correct and could i fix this problem myself or do i need to take it to a pro?
    if i buy the stk392-040, can i replace them myself?
    thank again for your help terryfic.
  • nateg Dec 16, 2007
    I have small green lines goin throughout the tv how do i fix it? i heard it was a chip.
    Genius:
  • 1,694 Answers
Problem as described is a repair = replace both STK392-040
convergence IC's....I use Panasonic brand = no recalls...
Do not use generics,,,,,,,,,,,,,T.
Posted on Nov 27, 2007
  • Vista Electronics Nov 30, 2007
    Your symptom " nothing happens when I adjust the blue" is
    common to all rear projection TV's, the repair is as I described .
    Has nothing to do with contaminated coolant..............T.
  • Vista Electronics Dec 01, 2007
    If you can un-solder and re-solder W/O doing damage....
    And if you can take board out & put it back......
Ws-65611 color shadows
You need to turn down the voltage on all 3 crt's. You have a red one, a blue one and a green one. Slowly adjust the knob down until you don't see the shadow any more. Then adjust your color in the user menu.
Aug 21, 2012 | Mitsubishi WS-65611 65" Rear Projection...
Akai PT5598HDI Rear Screen Projection TV With Blue Shadowing
If the ghosting is like a 3D effect its your convergence ICs , but if its like a blue Halo around objects that usually means your CRT coolant has congealed and will need replacement. The blue is the first tube to congeal for some reason, followed by green. Red seems to be not quite as prone to this. It is a normal occurrence n sets about 4 years old to need the coolant changed.
Jan 25, 2008 | Televison & Video
Curved red image on 46" Akai rear projection TV
Yes! an idea that the flyback transformer is shot!
Please rate our help to keep the free service online
Aug 29, 2009 | Akai PT4298HD Rear Projection Television
Picture has shadows with different colors (red, yellow, green)
Sounds like the convergence needs adjustment. You can do this through the menu-follow the on screen instructions. The idea is to line up the red, green, & blue.
Jun 24, 2009 | Hitachi 43FWX20B 43" Rear Projection...
I have the akai model # ptf492s and the white colors are yellow
I'm almost positive the problem is you have fungus in the CRTs. I know this sounds strange, but it's true. Basically there is coolant fluid in the lamps that develops fungus over time and turns yellow. It should be clear. If you take the back off the television, you will see the 3 lenses (red, green, blue) Each of the lens is held on with 3 screws. Remove the adjustable lens and look at each CRT. Shine a flashlight in they should look white. From what I've read, blue develops the problem first, then green. You can replace the fluid. Look up TV coolant replacement online. It's not to difficult, but you cannot get any of the fluid on the circuit boards or it will ruin it. Mine had a lot of fungus in the blue CRT and a little in the green. The picture looks 100% better now. Good Luck.
May 12, 2009 | Akai PT5492S 54" Rear Projection...
Double Letters-One in Green other Red in bottom corner
yes goto menue and goto convergence
line up all red blue and green cross hairs so thay are wite.
thanks.
daniel
Jan 13, 2009 | Akai PT4799HD Rear Projection Television
54" Projection TV
Your green gun in our tv is misagligned/out of focus. Your tv uses red, green and blue guns that layer in different shades and mix to create the different colors. Your green is a little off so the colors aren't mixing right which explains the green haze and the shadows. A tv repair man can fix this problem pretty easily and it isnt expenisve.
Aug 28, 2008 | Akai PT4298HD Rear Projection Television
White colors schemes seem off white color or brownish color and blue has green tint or baby blue color. .
Check the coolant in all three crt's as chances are it is contaminated (should be crystal clear). If brown (beer color), replace coolant in all three crt's and perform convergence adjust. Picture should be like new!!!
Good Luck!!!
Jul 20, 2008 | Akai PT5598HD 55" Rear Projection...
Problem is not adjustable = convergence mis-alignment is caused by failure of STK392-040 IC's. Replace both with name
brand only = no generics.I use Panasonic with excellent results.
Let me know if you want tech step-by-step detail...............T.
Nov 22, 2007 | Akai PT4298HD Rear Projection Television
Yellow and Blue shadow on left side of screen
Blue convergence off = needs convergence IC's replaced =
Would you like step - by - step how to ??????
Nov 07, 2007 | Toshiba 51H84 51" Rear Projection...
Akai PT5492S 54" Rear Projection Television Logo
125 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
