Question about Whirlpool WTW5300SQ Top Load Washer
Water Never Stops, Drum Never Fills, Cycle Doesn't Change
This sounds like the level sensor, and subsequent effects. Do you guys have any other thoughts? This was purchased only 4 months ago. Are these machines lemons?
  • micro2764 Nov 29, 2007
    this appears to have solved the issue.
  • 878 Answers
Micro, sounds like your drain hose is too far down the standpipe and it is siphoning. Pull the drain hose out and see if it fills ok. Catriver.
Posted on Nov 26, 2007
Kenmore 800.agitates and fills the same time
no usually the water stops coming in before agitation starts. check the water level sensor it might be plugged with soap crud
Oct 28, 2017 | Washing Machines
Machine retains water
Please check the small thin rubber pipe that is connected to the drum. it acts as a pressure sensor may be it is clogged and not able to give proper water level reading. use skewer or thick flexible wire to clean it.
Oct 03, 2017 | Zanussi IZ12 Front Load Washer
My washer fills and agitates, but when it gets to the rinse/spin cycle it stops and makes a loud grinding noise. Thanks for your time
If it doesn't drain the water after the wash cycle and the sound is more like a buzz then the first thing that I suggest you check is the lid switch. If the lid switch is damaged then the machine will not pump the wash cycle water out and it will not go into the subsequent cycles. The "grinding" or buzzing sound can be caused by an intermittent signal reaching relay switches or solenoids.
Feb 03, 2011 | Kenmore Washing Machines
Washing machine overfills and wont cycle to agitate
It is possible that the water level sensor is not working to switch off the inlet valve. So drain out and check the water level sensor, it is a pressure switch and can be checked if the diaphragm is damaged.
This sensore is fitted on the drum and works as the water fills, the water enters the jacket and pushes the switch on.
Hope this tip helps you.
Aug 22, 2010 | Roper Washing Machines
I have a candy AQ 1200, it fills with water then drum turns and s
sounds like m/c is waiting to heat up water but heating element is not working or timer switch not going on to next cycle.
Aug 21, 2009 | Candy Washing Machines
GE wcxr1070a washing machine. fills with water
Check the water level switch and the plastic tubing to the switch.
Sometimes soap scum stops up the plastic hose and the water level switch does not close to send power to the timer.
If the plastic hose is good and the water level fills and stops replace the water level switch.
Mar 21, 2009 | GE WCXR1070A
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Does complete cycle
When would the washer stop?
Is there water in the washer when it stops?
Feb 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Whirlpool WTW5300SQ Top Load Washer Logo
158 people viewed this question
Dan Webster
Dan Webster
Sal De
