Question about Hoover 24 in. DT999 Free-Standing Dishwasher
Hoover Whisper HD97E
5 year old machine, 2 weeks out of extended warranty!
Dishes still unclean at end of cycle & mushy dishwasher tablet remains evident
Although the machine runs it's cycle to the end, the main motor just runs for a few seconds then stops for a few minutes, then runs for a few seconds etc.
Sometimes the motor runs for a few minutes (I can hear the water being sprayed around), and then nothing happens for, say, 20 minutes, but the timer keeps counting down.
It happens on most programmes, and has gradually got worse over the last week. Cold rinse runs best, but even that still stops and waits sometimes
I took the motor/pump assy off, all looked ok and was free to turn. Put it back, no different. Must this be a faulty motor/condenser, or could it be a sensor or timer fault etc? Turning off and on again will always start the motor, even if only briefly.
Any advice most welcome, Thanks
  • 1,010 Answers
Unfortunately looks like you control board is at fault (located in the door)
Posted on Mar 10, 2013
  • 76 Answers
Try checking the water level, and level switch? Is the outlet hose high enough of the floor? If you tip the machine back you should see one or two clear plastic tubes, take one end of these and blow through them and the do it the other way round.
Posted on Nov 27, 2007
I have just bought the above dishwasher 2nd hand
cold water will not clean the dishes/aka break down the detergant
May 31, 2010 | Hoover 24 in. HD97E Free-standing...
There is a smell in the dishwasher and on the dishes when clean
I suspect stagnant water is laying in the bottom areas. You will have to lay the machine on it's back to access the pump.
May 27, 2010 | KitchenAid KUDK03ITBK Built-in Dishwasher
My Hotpoint Aquarius diswasher won't dissolve the washing tablets
I don't have a solution, but the exact same problem is happening with my dishwasher. Nothing is getting cleaned properly.
Did you manage to get the problem fixed?
Jun 01, 2009 | Dishwashers
Our less than 1 year old Whirlpool dishwasher model DU1145XTPQA is taking as much as 2 and 3/4 hrs. to complete the entire dishwashing (normal)cycle. This is much longer than it used to take.
Contact Whirlpool service immediately to get a service call scheduled before the warranty expires.
Most dishwashers that begin taking longer to complete the cycle have a failed heating element but that also normally means that the dishes do not get fully clean and the glassware has a film on it after the cycle ends.
Good Luck!
Apr 07, 2009 | Whirlpool 24 in. DU1148XTP Built-in...
LG Dishwasher LDF6810ST
As I had the same problem, I worked on my machine and found out the heater unit was not working (it is a brand new machine ! - remark : as I moved overseas, LG did not cover it with their warranty).
But back to what I did : I ran the check program (instructions can be found in the Service Manual) and verified it was sending voltage to the heater on step 36. So I checked the heater unit (in the bottom of the machine) and found it was burned or open. So I ordered a new heater assembly ($40 on eBay), replaced it myself and am completely happy with the results.
Remarks : the heater is powerful enough to heat cold water to the temperatures required (I don't have hot water in the faucet); it seems that the heater also produces heat for the drying cycle (my dishes were completely wet at the end of the cycle before, now they get completely dry). My only disappointment, mentioned by some in the forum, is that the outlet during the drying cycle is in the bottom of the door, so steam condensates into droplets on the kitchen floor. But now I get clean dishes, and this machine is amazingly silent and efficient. Good luck to you !
Nov 10, 2008 | LG LDF6810ST Stainless Steel Built-in...
White Residue
most likely it is your detergent. palmolive eco is notorious for leaving a white chalky residue on dishes. try this out before calling a service tech: put unclean glasses in the dishwasher and in your soap dish and rinse cycle cup put 1/2 cup of distilled white vinegar. if it cleans (or improves) your dishes, then your detergent is the culprit.
Jul 29, 2008 | Frigidaire 24 in. FDB510LC Free-standing...
Maytag dishwasher jet clean eq plus water not filling with water
My Maytag Jetclean Flexiload is 4 years old. Upon choosing a program the timer counts down but little action is heard. Near the end of the cycle an Error message comes up. The dishes are stiil uncleaned.
Apr 23, 2008 | Dishwashers
Error e3
Drain pump probably not working. Put machine on cycle 7 and it should turn on the drain pump straight away. you can hear this near the bottom of the machine. if it is silent hten the pump probably needs replacing. I repaired mine be removing it and then dismantle the magnet from the tube then give it a good clean out.
Feb 03, 2008 | Hoover 24 in. HD97E Free-standing...
Top rack dishes are not clean
My Whirlpool dishwasher is only 2 years old and I started having the same problems. I dismantled everything I could and washed and scrubbed the entire unit with EVERYTHING..to no avail, dirty dishes!! But I discovered a remedy! Try using Lemi-Shine for about a week with your regular wash-soap. If you are using the tablet form of soap, stop and try the powdered form. Follow the instructions on the Lemi-Shine container. You can find it just about anywhere for around $3.50. I was within "5 seconds" of replacing my 2 year old Whirlpool dishwasher when this caught my eye and I figured why not try it too? After the first wash I noticed a big difference the cleanliness of the dishes..and now it is running GREAT after 2 weeks!
Aug 21, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Hoover 24 in. DT999 Free-Standing Dishwasher Logo
348 people viewed this question
Top Hoover Dishwashers Experts
Owen Barnes
Are you a Hoover Dishwasher Expert? Answer questions, earn points and help others
