Question about Garmin nuvi 350 GPS Receiver
My Garmin does not turn on when pressing the power button.
My Garmin will not turn on or off using the power button. The only way I can turn it on is by plugging it to power in Car or Home.
Can you please let me know if I had the defective piece or if something is not working as it suppose to be.
I have the same problem, I just got mine two days ago and I charged it fully and it still wont turn on when not connected to any power source. I am probably just going to exchange it when I get the receipt from my parents in about a week but I wish there was something I could do on my end. So far haven't found any solutions. It also doesn't seem like this is a common thing which is good (but bad in my case because it doesn't help me any lol)
Posted on Dec 27, 2007
    Problem Solver:
  • 12 Answers
Hotmail user may well be right. What does your Battery Icon (as shown on Page 3 of the Owner's Manual (downloadable from reveal about the charged state of your battery? Further info pertaining to your battery can be found on pg 64 of the Owner's Manual
Posted on Dec 09, 2007
May be you do nto have the battery charged enough to switch it on without any power supply
Posted on Nov 27, 2007
Nuvi will not turn on
What model Garmin Nuvi ???....
On occasion, your Garmin GPS may experience technical malfunctions, including failing to power up.
When this happens, perform a manual hard reset of the unit.
A soft reset entails holding the power button until the unit powers down, and then pressing the it again to power the device back up.
However, when the unit won't turn on, a soft reset won't work. In this case, a hard reset is the only way to get the device up and running again.
Unplug power and USB cables to disconnect all sources of power to the unit.
Place your thumbnail into the groove located below the Garmin logo on the face of the unit.
Pry the faceplate off using gentle pressure.
Press the reset button and hold for approximately 3 seconds.
When the device is facing you, the reset button is located in the middle of the right-hand side of the front of the device.
Snap the faceplate back into place.
Press the power button.
Your GPS should now turn back on.
Garmin Nuvi With No Power
A Garmin Nuvi is a type of GPS device that can help you find your way around when traveling by motor vehicle.
You can mount the Garmin Nuvi inside the windshield of your vehicle and allow it to acquire the satellite signal.
This tells the device where you're located.
After that, you can find simple directions to get to a new location by entering the address into your Garmin Nuvi.
If you find that your Garmin Nuvi has limited or no power, you will need to do some troubleshooting to get it to work.
Change the fuse within your unit's power cable.
If your Garmin Nuvi has no power, the fuse may be out, meaning the device cannot be charged.
Plug your Garmin Nuvi into the power supply of your vehicle and turn the vehicle on.
The device cannot charge and get power unless the vehicle is running.
Allow the Garmin Nuvi to charge fully.
You might be unplugging it from the power source too soon, which could cause the device to have little or no power.
Regulate the temperature of your Garmin Nuvi.
It may not function properly if the temperature is too cold, below 32 degrees Fahrenheit, or too hot, above 113 degrees Fahrenheit.
Aug 10, 2013 | GPS
How do you reset your garmin 910xt?
To master reset your Garmin 910xt you first have to turn it off using the power button. then press and hold in the mode and enter buttons, while still holding the mode and enter buttons press and release the power button. After letting go of the power button you can release the mode and enter buttons. You will know that it worked if it powers on and starts the set up wizard. If it doesn't you should try these steps again. Just know that a master reset will erase all the data on your device.
Aug 09, 2013 | Garmin SDM3 Footpod Foot Pod for...
Pushing button across,nothing happens
Try resetting the unit by pressing the reset button or on the newer 205's , turn off the power button then turn back on but hold the button for about 15 seconds till it reboots again. This should reset your unit. You should go to the Garmin site and update your unit. I will attach a link to the Garmin site. It will explain the update process and you can also find a copy of the owners manual if needed.
Thanks for using FixYa
Sep 06, 2011 | Garmin nuvi 205W GPS Receiver
Used my garmin edge 305 today on the ride, it worked fine, powered off after the ride. Got home turned on to review my stats and then powered off and went to upload and wouldn't upload, so tried to turn it...
Edge 205 or 305 often crash, then impossible to power on again.
Here is the way to reset the Garmin edge :
Soft reset : hold mode and lap/reset buttons for 10 seconds
Hard reset : device should be powered down, hold start and mode buttons for 3 seconds then pulse press the lap/reset button.
After soft reset, you need to hold start button for up to 10 secs before it starts.
After hard reset, you will loose all your data, including profiles.
Jan 30, 2011 | Garmin Edge 305 GPS Receiver
My garmin nuvi will not shut down. The screen is white. Is there a reset button on the unit?
In some nuvi models there is a reset button.But in some nuvi models there is no reset have mentioned only garmin nuvi but not mentioned the model of the garmin nuvi.But still i will mention the reset button location of some garmin nuvi models.Hope that helps you.
The reset button/procedure for garmin nuvi models
In order to reset Garmin device or enter into maintenance mode, perform one of the following procedures:
Power off Garmin unit. Press on continuously the upper top left corner of screen and then power on the unit by pressing once on the Power button. You should be prompted to clear all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
above works on Garmin Nuvi 660, 680 series.
Turn off Garmin device. Press down on bottom right corner of the touchscreen, and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
above works on Garmin nuvi 200, 250, 360 750, 760 series unit. Garmin Nuvi 360 on how to perform the hidden reset function.
Reset button on the bottom of the nuvi backside.
Click on the link below to get the exact location of the reset button.!.pdf also check out this link too Thanks. keep updated for any more can rate this solutionand show your appreciation.
Jun 11, 2010 | Garmin GPS
Garmin is unresponsive. Won't power up or turn
I have a Garmin c340 that would not turn on.
I found the hidden reset button and it works now.
With the display unit facing you, the aluminum cover plate has the the word GARMIN on it. Use you fingernail under the word Garmin and the cover plate comes off. The left part of the cover stays attached to GPS and the right side lifts up exposing the RESET button. I pressed RESET and POWER together and it works now.
Mar 10, 2010 | Garmin StreetPilot c340 GPS Receiver
Garmin wont turn on
IQ-M4 may be different but f it is like the IQ-3600 then press POWER button while pressing RESET then release POWER button.
Aug 08, 2008 | Garmin iQue 3600 GPS Receiver
To power the unit back on, press the "Mode" and "Reset" buttons at the same time. Let go of those two buttons, press the power button, and the unit will turn back on."
Feb 27, 2008 | Garmin Forerunner 305 GPS Receiver
Garmin streetpilot i3 wont power on
WARNING: You will lose all user data when you do a master reset.
To erase all user data on the device, please follow these steps:
  1. With the unit turned off press and hold the thumb wheel down, then press the back arrow and hold down, then press the power button.
  2. When all 3 are held down a message will appear that reads "DO YOU REALLY WANT TO ERASE ALL USER DATA". Select "Yes".
  3. Let go of the buttons and go through the reset sequence. The unit will need to sit outside to acquire satellites.
Dec 18, 2007 | Garmin StreetPilot i3 GPS Receiver
Garmin street pilot III
Push the power button to turn it on then count to 5 then hit enter. Then count to 5 again then hit enter. Once there hit the power button with a real quick press. The power button is also the screen brightness button. Someone may have turned it all the way down. OR the back light could have gone out.
Aug 16, 2007 | Garmin StreetPilot 2610 GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
60 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
