Drop Down Box
In Microsoft Excel, 2003 how do you delete a drop down box?
    Problem Solver:
  • 5 Answers
If it won't delete when you select it and hit the Delete key, then the drop down box is not a control box but a Data Validation box. In that case click on it then from the menu click Data > Validation, then in the 'Allow' drop down list select 'Any Value'. Click OK.
Posted on May 21, 2008
  • 3 Answers
Select the drop down,
Right Click mouse button
from the menu that appears select delete
Posted on Apr 27, 2008
Remove page breaks in excel
We would appreciate if you share with us your Excel version as well so that we can give you a more specific solution to your issue. In the meanwhile, you can refer to the following steps to delete a manually-inserted page break in Excel 2007, Excel 2010, or Excel 2013:
(Important: You cannot delete page breaks that Excel has added automatically. Adding manual page breaks, changing the page orientation, or adjusting column widths and row heights may affect automatically-inserted page breaks.)
1. Select the worksheet that you want to modify.
2. Go to "View" tab, then go to "Workbook Views" section, and click "Page Break Preview".
(Note: You can also click "Page Break Preview " on the status bar)
(Important: If you get the "Welcome to Page Break Preview" dialog box, click "OK". To avoid seeing this dialog box every time you go to "Page Break Preview" view, select "Do not show this dialog again" check box and click "OK".)
3. Now do one of the following:
a) To delete a vertical page break, select the column to the right of the page break that you want to delete.
b) To delete a horizontal page break, select the row below the page break that you want to delete.
(Note: You cannot remove automatic page breaks)
4. Go to "Page Layout", then go to "Page Setup" section, and click "Breaks"
5. Click "Remove Page Breaks"
(Important: You can also remove a page break by dragging it outside of the page break preview area {to the left or right for vertical page breaks, or up or down for horizontal page breaks}. If you cannot drag page breaks, make sure that the drag-and-drop feature is enabled. To check the status of your drag-and-drop feature, click office button , click "Excel Options" tab, click "Advanced", go to "Editing Options" and make sure you have checked the "Enable fill handle and cell drag-and-drop" option.)
To refer to a pictorial explanation of the above steps, you can refer to "Delete a manually inserted page-break" section on the following Microsoft Support Page:
http://office.microsoft.com/en-in/excel-help/remove-a-page-break-HA102576899.aspx?CTT=1
GuruAid.com
Jun 22, 2014 | Computers & Internet
Size of the excel file increased from 721 KB to 50MB
Many businesses use Excel to track their data and expenses.
However, you can run into problems when files grow too big.
Try reducing the size of your Excel files in different ways to eliminate your storage problems.
Remove unnecessary graphics and fonts from the Excel file.
Simple report data doesn't need a lot of excess formatting to make it attractive.
If you need to keep different fonts in your file, reduce some of the font sizes you originally used.
Reduce the number of pivot tables you allow in your data analysis.
Run your pivot table wizard when dealing with involved calculations.
When given options to format the file, choose those that allow the data to refresh instead of adding a new table.
Input your data, close the file and save as an Excel (XLS format) file and as an HTML (XML format) file.
To do this, choose "XML Data" in the "Save as type" drop down box.
Change the name of your document as well, so you can tell the difference between the two files.
Open the XML file and save it back into the regular XLS file to create a smaller file than the original.
Again, rename this file, as well as changing its type. This act removes odd programming left from past calculations since the last "save."
Check into file compression software such as OzGrid.
These products exist because you cannot open a file once it gets too big.
Compress the XLS data by compelling the program to recalculate the cells used for your file.
Excel File Size Reduce Software 7.0
http://www.newfreedownloads.com/Business/Spreadsheets/Excel-File-Size-Reduce-Software.html
http://www.ozgrid.com/
or
Microsoft Excel files can contain thousands of cells filled with data.
When you combine this information with graphics, such as charts and graphs, as well as ever-expanding links to other worksheets, you can end up with an enormous file that takes up precious system space and slows Excel down.
While there are many software programs available that promise to shrink Excel files, there are many ways to reduce the bulk without downloading a new application.
1. Click on any cell in the Excel file you want to reduce.
Open the "Go To" dialog box in Excel 2007 by clicking the "Find" drop-down arrow on the Home tab of the ribbon and selecting "Go To."
In Excel 2003 or earlier, go to the "Edit" menu and select "Go To."
You can also use the keyboard shortcut "Ctrl+G" in any version of Excel.
2. Click the "Special" button on the "Go To" dialog box.
Select "Blanks" and click "OK." Click the "Clear" drop-down in the "Editing" group in Excel 2007 and select "Clear All."
In Excel 2003 or earlier, go to the "Edit" menu, point to "Clear" and select "All." This will clear any blank cells to help reduce the file size.
3. Go to the very last cell containing data in the Excel file.
Select the entire row beneath this cell by clicking the number to the left of it.
Hold "Ctrl+Shift" and then press the down arrow key to select all of the cells beneath this point.
4. Click the "Clear" drop-down in the "Editing" group in Excel 2007 and select "Clear All."
Select the column to the right of the last cell. Hold "Ctrl+Shift" and then press the right arrow key. Again, select "Clear All."
5. Repeat Steps 1 through 5 for any other Excel files that are linked to the workbook you are trying to reduce.
Save the files and then check the new file size by clicking the "Office Button" in Excel 2007.
Point to "Prepare" and then click on "Properties." In Excel 2003 or earlier, go to the "File" menu and select "Properties."
The file size will be listed on the "General" tab.
http://www.ozgrid.com/Excel/ExcelProblems.htm
Apr 22, 2013 | Microsoft Office Professional 2010
Reduce the size of excel file
or
Apr 22, 2013 | Microsoft Office Computers & Internet
I WOULD LIKE TO CHANGE MY EXCEL FILE IN READ ONLY MODE
amjbritto,
There are two ways to do this, depending on what extent you want to protect the spreadsheet.
Windows Read-Only method:
  1. Save and Close the Excel file.
  2. Using Windows Explorer, locate the Excel file in its folder.
  3. Right-click on the file name
  4. Click on "Properties" at the bottom of the drop-down window.
  5. Check the [x] Read-Only box and [OK]
  6. * DONE *
Excel "Protect" Method:
  1. Open the Excel spreadsheet that you want to protect
  2. On the top menu, select [Tools]
  3. Click [Protection] on the drop-down menu
  4. Select [Protect Workbook]
  5. Check [x]Structure and [x]Windows
  6. Enter a password if you wish, but remember it!
  7. Click [OK]
  8. Save and close the spreadsheet and test the protection.
  9. *DONE *
Thanks for using FixYa.
Oct 06, 2010 | Microsoft Excel for PC
Since upgrading to Windows 7, I can't print from Excel (Office 2003). When I try, a "Print to File" window pops up even though that check box is unchecked in the print window. I can print from Word and...
try to make the installed printers as a default printer and then try to print.
in case that does not work when you try to print from excel, click on the drop down for printer name and select the correct printer.
This should help you
Jul 12, 2010 | Microsoft Excel for PC
What is formula to use 5 point drop down list to prompt entry of cell value into specific location
You can use cell validation.
Select the cells you want to have the dropdown list.
Press the following keys "alt" "d" "l" and you get a message box.
select List from the drop down.
Now you can type in your list in the blank box separated by commas
Nov 29, 2009 | Microsoft Excel for PC
How to set password for excel sheet when iam opening?
1. While saving an excel file, on the save as box, click on "Tools".
2. On the drop down munu, click on "General Options"
3. On the password to Open box, type a password
4. On the password to Modify box, type a password
If you want users to be able to read the file, check the box that says "Read-only recommended."
Mar 24, 2009 | Microsoft Computers & Internet
Search options in drop down menu
It is possible. But you need to write a macro to map the selected item number to price.
Jan 26, 2009 | Microsoft Excel for PC
MS Wireless Optical Mouse 5000 - Magnifier
All the buttons are programable and easily accessed through the mouse icon in the startup menue. Click Statup, Click the mouse program icon, a window appears with each of the mouse buttons listed with drop down menues. Click the drop down menue of the button of interest, select one of about 20 choices (in my case "disabled"), click Apply, click Save.
Dec 10, 2008 | Platinum Microsoft Wireless Optical Mouse...
Excel
Hey dude,
Select both the columns and click on Auto-filter option. This will give you a drop-down list box to select data of your choice.
Sep 06, 2008 | Computers & Internet
Computers & Internet Logo
326 people viewed this question
David Payne
David Payne
