97 RAV4 door won't open. cable is off and door won't unlock. how do I fix it? panel is off
These can be a nightmare!
Try pushing / pulling all cables and rods available. And key operation if connected.
If there is a solenoid to operate it, remove the connector and use a meter to find the motor wires. Cautiously apply 12v from a handdrill battery - first one way - then the other to see if the drive motor will unlock it.
As a last resort - Drill a 1/4" hole in the lock body - and use that as a pilot hole for a 20mm holesaw - destroy the lock mechanism to gain entry - the lock was beyond repair anyway - so needed replacement - Just don't damage other components if possible.
You can operate it from the lcok actuator... two rods across the door try to slide them
I cant open the door with my spare key
