Question about Mitsubishi WD-62528 62 in. LCD Television
I have a 60’ Mitsubishi tv WD 62528 that flashes an orange lamp light?
SOURCE:
wppierce65
SOURCE: My Mitsubishi WD-62528 has suddenly developed a
Replaced the lamp.
Posted on May 15, 2009
  • 556 Answers
SOURCE: Mitsubishi tv model # wd-52527, lamp light flashing,no picture.
I would say so.
Posted on Aug 18, 2009
SOURCE: theres a red light on the front of my mitsubishi
Your lamp has expired, replace it and make sure that you reset the lamp to 0 after replacement.
Posted on Oct 02, 2009
SOURCE: I have a Mitsubishi WD 52628. I replaced the tv
try turning it on hold the menu button for eight seconds menu pops up try reseting the settings again as before you had the problem
Posted on Feb 10, 2010
SOURCE: WD-62327 Lamp
OSRAM VS. PHILLIPS
This is about buying replacement bulbs for the WD62327 TVs.I dont know about the other models but I purchased a PHILLIPS replacement bulb and it worked for about a week and then those dumb flashing lights and no TV. I did some research and others were saying that you had to replace some condensers. Shop would do it for 600 dollars..Well i sent the bulb back and bought an OSRAM replaement bulb. The TV is now working perfect.
Posted on Jul 14, 2010
I have a mitsubishi 60 in rear projection tv and it only blinks 3 times and dont come on can u help me
the lamp door pushes a switch if the relay is bad it wont register the door is closed
Nov 12, 2012 | Mitsubishi WD-62528 62" LCD HDTV
Tv wont go on at all. flashing light on front. where it says timer...
How old is your TV set it could be a few things but most likely for this set's it is usually the LAMP
so I would start there, first the lamps are rated 6000-8000 life hours 2-3 years of use
Oct 11, 2010 | Mitsubishi WD-62528 62 in. LCD Television
I have a Mitsubishi TV Model# wd-62528, the red light comes on on the lamp light
Need to replace a new lamp. Or if you still see picture, go to menue and reset lamp. I f no picture, need to replace a lamp.
May 09, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Blinking orange lamp light
if the lamp light is flashing and the tv won't come on you need to replace the lamp. check your owners manual for how to do it or call mitsubishi customer service
Jan 26, 2010 | Mitsubishi WD-Y57 57" Projection HDTV
Replaced lamp about a month ago and now getting yellow/orange flashing light under lamp. What is the problem
Check in your operating menus on the TV as there is most likely a lamp timer reset that needs to be performed.
Oct 14, 2009 | Mitsubishi WD-62528 62 in. LCD Television
Lamp lcd
Make sure lamp door is properly on, there is a sensor on the door.
Sep 19, 2009 | Mitsubishi WD-62528 62 in. LCD Television
TV does not come on
Similar problem with my Sony. Unplug for 36 hours from the wall and it fixed my problem
Dec 16, 2007 | Mitsubishi WD-62528 62 in. LCD Television
Mitsubishi WD-62528 62 in. LCD Television Logo
23 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
