Green led light flashing on 700p proview flat panel and no picture
Hello, i have a proview 17in flat panel computer monitor model #700p that will not show anything, and the green power led indicator is on but flashing slowly. can you guys please help me. thanks
  • 1 more comment
  • Gregory Arseneau Oct 17, 2008
    I have an optiquest 900s crt monitor ( which I can't track down). Anyway, the power light flashes green and I get no image on the screen. The monitor was working fine until I moved it.I was very careful during the move and did not subject either the tower or the monitor to any undo jostling. Any ideas?
  • chettle Feb 07, 2009
    I turned my AOpen F2925 monitor off the other night, the next morning... all I get is green flashing light. No change in anything else. I did nothing but turn the monitor off for the evening.
    Had the computer to the shop, he hooked it into another monitor, nothing wrong with the computer.
    Bring it back home, same issue. Monitor doesn't do anything except green flashing light.
  • Anonymous Mar 09, 2009
    I have a similar problem in that all of the sudden the lights on the front started blinking and I can't get any type of signal.
Usually when the power light flashes and the screen remains blank and unlit, your power board is in fact malfunctioning. This is not always the case, as the problem can sometimes reside in the input or inverter boards. I would first recommend that you feel comfortable with opening up your screen and looking at components. It can be a little overwhelming at first. BEFORE PROCEEDING, UNPLUG POWER TO MONITOR. If inclined to check, carefully open the casing around your screen. I have not worked on your particular model, but some are easier to open than others.
Once opened, you need to gain access to the circuit boards. Sometimes they are not protected by metal, other times they are completely encompassed. The flashing power light usually indicates that a capacitor(s) is(are) malfunctioning. To see if this is the issue, locate the power board (usually the one with larger-size components) and look for any capacitors having bubbled or raised tops and/or oozing a brownish liquid. If not on the power board, look elsewhere for the same symptom.
PLEASE BE CAREFUL!!! If you have recently had your monitor plugged in, the larger capacitors can still carry a charge. If you cross the leads of a capacitor while it carries a charge, it will discharge. It won't hurt any other components, but if you cross the leads with something that is in direct contact with yourself, you can get quite a jolt! There is usually a large voltage capacitor (normally just one) on the power board of these screens. I tested one with a multimeter after immediately unplugging it, and it still held a 166V charge! So please, do this with caution.
If a bad capacitor has been found, simply remove the old one and solder a new one in its place!
Posted on Mar 26, 2009
  • 116 Answers
You need to replace the power supply! I work with these all of the time, the most common problem with thes montiors is the Power supplies do no generate enough charge to power it up to display an image! If the Power supply does not work I would look into getting a new monitor because then it is truly involved! Bad inverter, or blown LCD. I speculate that if your not getting any video after trying the new cord. replace the monitor! Sorry!
Posted on Nov 26, 2007
2 Suggested Answers
  • 16 Answers
SOURCE: green led light flashing on 700p proview flat panel and no picture
I have a similar problem.
Switching the screen off (front panel button) and on again after waiting a few seconds fixes it.
This is a recent problem, so I'm expecting it to get worse and worse until one day!!!!!!
Posted on Feb 10, 2009
How can i download driver for proview 700P?
you can download it from a website called driver guide. I have downloaded it and confirmed no viruses and to be the proper driver. Click here for the proview 700p driver
if you need further assistance please let me know, Thanks-Midwest-tek
Aug 28, 2010 | Proview PL913B 19" Flat Panel LCD Monitor
My proview 700p has lines and picture jumps can anybody help me please
Look at the power supply first, look for burnt parts, bad capacitors, etc.
Please post back what you find.
Nov 24, 2009 | Proview PL913B 19" Flat Panel LCD Monitor
MAG 700P monitor display goes black after 60 seconds
Can you send pictures of the power board to me at I will check our service manuals for the model and get back with you about a solution.
Corporate Computer
Jun 29, 2009 | Mag Innovision LT782S 17" Flat Panel LCD...
How to use this Proview LCD Monitor 17" 700P AS A TV Screen
No. The newer LCDs can do both. But they are a TV to start with the option to hook up a Desktop.
Feb 08, 2009 | Proview PL713S 17" Flat Panel LCD Monitor
Preview 700 P
you should change al lthe caps in the PSU.. you can get them all from Maplins for a few pounds.
best get 105 centigrade ones
Oct 25, 2008 | Proview XL370B (Black) 17 in. Flat Panel...
Oct 03, 2008 | Hanns.G Corporation JW-199DPB 19" LCD...
Need help: ProView 700P Silver LCD Monitor
You do NOT need a driver. Your monitor is broken. The high voltage power supply that provides power to light the CCFL cold cathode fluorescent lights is broken. The most common problem is that the 470uF 25V capacitors on the power supply circuit board are bad. Bad Caps have a swollen and sometimes leaky top. There are 6 capacitors that cost about 50 cents apiece from . Buy high temperature replacement capacitors rated at 105C. If you can't de-solder and resolder have some 14 year old kid do it for you.
Feb 26, 2008 | Computers & Internet
Any high switching power supply of the same voltage and amperage rating will work for you. You may have to cut the end off of your old one and wire it to the new one to make it work but don't waste your money buying a specific power supply.
Good Luck!
Feb 16, 2008 | Computers & Internet
Proview 700p problem
Jan 16, 2008 | Proview PL 566s 15" Flat Panel LCD Monitor
Computers & Internet Logo
2,011 people viewed this question
David Payne
David Payne
