Question about Kenmore 52642 / 52644 / 52649 Side by Side Refrigerator
Kenmore side by side not cold
Sounds like it is running w/o compressor. Fan goes good. I can feel air moving in both freezer and fridge. Compressor kicks on and then right back off in less than 20 seconds. Everything is clean and no major heat issues noticed in back. Refridgerator is located in the garage if that makes any difference. I have a freezer right next to it that works just fine.
  • crowe8 Nov 27, 2007
    I tried to locate the "relay overload" and there is no such thing on the wiring diagram or parts list. Might it be part of the compressor? I even emailed Sears to see if hey could locate it and they replyed "no part." Is the capasitor or starter the same thing?
  • 213 Answers
The relay overload on the compressor is bad. very common problem. replace relay overload and it will work again. unplug from wall until you replace it.
Posted on Nov 27, 2007
  • chris hooper Nov 27, 2007
    its plugged into the left side of the compressor. mosy if the time its under a plastic cover.
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
Kenmore side by side fridge. Green temp light flashing for fridge side, freezer side working fine. Fridge side not cooling.
possibly frosted up at the air door between the fridge and freezer, or the fan in the freezer is not pushing cold air into the fridge side, if you can not hear a fan running in the freezer when the fridge is running (compressor on) then change out the fan
Jul 18, 2011 | Kenmore Side by Side Refrigerator
The compressor runs and freezer is cold, however the refrigerator side isn't cooling well. Doesn't feel like any air is blowing in the fridge, only the freezer. I tried turning off/resetting the system...
Your model numbers are a waste of time...
Kenmore 5522 / 655224 / 55222 / 55229
Side by Side Refrigerator... PICK One...!!!
"The" fan...??
There should be TWO fans running...
and the FAN that REALLY make the difference in your
described symptoms ... will not run with the DOOR
open (your evaporator fan).
Possible issues:
Fan motor, blades/air blocked by ice, broken blade,
defective door switch or control board...
I always preach... giving a troubled refrigerator
a THREE DAY defrost... but the other day I found
a solid ice block sitting all SNUGGLY in the middle of
an evaporator...
If you are not willing to do that... (3 day defrost)
open it completely and have a REAL GOOD look
around the EVAPORATOR & FAN.
Never use HOT air... soft plastics can be easily ruined.
Take your MODEL NUMBER...
And look on:
Search Over 2 1 Million Appliance Parts
PartSelect Appliance Parts and Repair Help
repair clinic
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Happy hunting...
Carnac the Magnificent
Aug 16, 2017 | Kenmore 5522 / 655224 / 55222 / 55229 Side...
Freezer is ok, but fridge is not cold enough
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked.
Sep 01, 2009 | Kenmore Refrigerators
Kenmore side by side is not getting cold or freezing
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
Is the refrigerator completely dead?
If so, see “It's stopped completely.”
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
The compressor
The Thermostat
The overload, relay, or capacitor
The defrost timer
The condenser fan motor
The freezer and the fridge are cooled by the same system, air is moved to the fridge by a fan from the freezer, either the circulation fan is defective or the fridge thermostat is defective.
Don't forget to rate;
Jul 05, 2009 | Kenmore 53642 / 53644 Side by Side...
Problems with Whirlpool 21.0 cu. ft.
checklist: freezer fan running, compressor fan running, compressor running, any frost buildup on back wall of freezer. you may have to take a rag and touch the compressor to feel if its vibrating to see if its running unless you can hear it. please reply
Jun 12, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
How can I tell if my fridge isn't working?
Unplug the Ref for 15-20 min. take off the cover so you can see the compressor, then plug it back in and listen for the compressor to start. You should be behind the Ref so you can tell the difference between the fan running or the compressor.
The compressor should start and keep running.
The fan cooling the compressor should be running.
The fan in the freezer should be running.
You should feel cold air coming into the Fridge side from the freezer side.
Jan 12, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Kenmore Refrigerator Model #795.75004401 Doesn't get cold
Hi. Make sure all your fans are working. When checking fans, open the door and push the light button in. Some models the fan stops or dampers close when the doors are opened. Put your hand in front of the vent and see if you feel air. Do the same in the refrigerator and freezer. If you feel air from both, check and see of the compressor is running. There is a fan next to the compressor and should be running when the compressor is running. You have a motherboard behind a cover on the back of your refrigerator that controls all of these functions. It could be defective. Motherboard failure is common as well as compressor and evaporator motor failure. Fan Motor failure is common for refrigerators in storage for a long period of time. The motors are weak and can't start. This goes for all new refrigerators. I sell refrigerator items on Ebay as username, themackshack. Good Luck, Mack
Jan 10, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Jenn Aire side by side - freezer and fridge not working
Yes the compressor could be stuck but it's also possible the PTC could have failed - each will show the same symptoms. If you're a tech you can check the compressor or you can just replace the PTC also known as "relay". Part # 12002784 should run somewhere around $60.
Dec 30, 2007 | Jenn-Air JCD2389G Side by Side...
Kenmore 52642 / 52644 / 52649 Side by Side Refrigerator Logo
147 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
