Question about Poulan Garden
WILL NOT IDEL - Poulan Garden
    Problem Solver:
  • 11 Answers
Need more info
Posted on Aug 04, 2009
SOURCE:
1996 GMC jimmy rough idel and dieing when driving.
i have seen many strange things happen with the distrib cabs on these
Aug 22, 2012 | 1996 GMC Jimmy
High idel
check if all vacuum air OK . check the idel air Beside idel control .check the agr . or you have bad voltage regulator .
Nov 20, 2011 | 1999 Dodge Ram 2500 4WD
Nun stable of RPM
Check for vacuum hose off, broken,cracked, or loose at a connection.
Mar 14, 2011 | Toyota Corolla Cars & Trucks
What causes the vehicle to idle down then back up only when stopped or in park?
The drag from the transmission and the power assist for the power brakes andthe extra load of the brake lights on the electrical sytem, may accially slow down the altentor lowering the total system voltage, in the long run changing the voltage at the engine sensers, throwing the computers tune of the motor off some.. cars built since 1980 that have fuel injection shouldn't do this very little or none at all. The reason is that the fuel system has an automatic idel speed motor that catches the idel and holds it at the right level no matter what the load. This system has limits and problems that limit it's ability to keep the idel right. Then theres the other way around. There's a vacume leak or other problem making the engine idel too fast and when the loads are added ( power steering , in gear automatic trans, airconditioner, raditor fan ) bring the engine to the correct level and the system will keep it from going any lower.
Jun 01, 2010 | Cars & Trucks
Starts but will not idle
Most Lesabre have the 3.8 engine. The engine has a device called an automatic idel speeed motor or AIS for short. It's held on with two torx 20 screws and a 4 wire electrical connector on the side of the Throttle body. BUT BEFORE YOU GO REPLACING THIS DEVICE THAT CAN COST OVER $50. Try this first. Don't drive the car around this way just test it! Remove the big vacume hose from the power brake booster and put your finger over the end of the hose going to the motor. Have an asstant start the car and hold the gas so it'll keep running, trying to go as slowly as they can. Slowly remove your finger from the end of the hose and the motor should pick up speed. you should be able to get a good idle with your helper completly of the gas. if you do the idel motor is'nt working ( right) so your not done checking. Let's say you can't even get a fast idel that stays. The timing chain needs checked and other vacume or engine control codes need checked. Has the check engine light been on? ( with the engine running) . If it has the idel motor will set a code as will a cam senser and all the other sensers on the car. Follow code charts if a code is found. Most auto parts stores will check your car for free for codes but their recomendations very with the experience for the operator of the tool, and if they were good enough to make the mechanics money why are they in a parts store? If you can acheive a good idel playing around with the vacume hose then put it back on and go to the next step. Remove the Idel motor and clean it and the hole it came out of with oven cleaner. Just like cleaning an oven don't get it on you or the wiring part of the motor. With an OHM meter the pins will show two different pins hooked together ( two Pair) If you get only one it's bad. Every pin is connected to just one other pin. If not it's bad. You can get new cheap ones that are bad. I use cheap ones and cross my fingers. If they work the first time their good for a long time. Then you have to learn the idel. Try to learn the idel with the old one cleaned first. Start theengine and hold the idel with the gas pedel. after holding the speed at 2000 Rpm for two minutes ( a good engine will do this easy) let off slowly it should idel down slowly then (catch) and speed back up on it's own. If it does your fixed and go on your merry way.
Feb 15, 2010 | 1999 Buick LeSabre
Does the pilot screw alter the air intake on the Carburetor of a gsxr 750 slingshot 1988 model
Certainly you best adjust these screws with a vacume gauge set connected and set them all the same as the gauges dictate as the number of turns out is just where you start. The sync needs to be set first with the idel turned up too high when it's right turn the isel back down and check again as the idel is low nows the time to correct differences with the idel mixture screws. As the idel mixture is always on they effect the total mixture at all enf=gine speeds but lesser so at high speeds only noticeable at the gas pump carefully cheaking
Dec 04, 2009 | 1988 Suzuki GSX-R 750 J
Rough idle then stalls
Vacume leak or bad idle motor. With the car in park and running with the hood open listen for leaks moving your hand around the different hoses looking for a change in the sounds that you hear. The idel motor also makes the car idel up to 1500 RPM or so right at start-up then idel down, If it doesn;t the idel motor is likly. Check engine light is on when running? Test for codes, Follow code test charts don't skip any steps!.
Nov 02, 2009 | 1998 Chevrolet Malibu
Need info on rough idel 5.9 cummins
bad injector?
easy to test with vom, just check from terminal on injector to ground if one reads different thats the problem, you do need to disconnect wire to check, my help is free and will be glad to help further just vote fixa..LOL my rating is all I care about. Hope yu can help me too.
Dec 19, 2008 | 2004 Dodge Ram 2500
Garden Logo
19 people viewed this question
Top Poulan Garden Experts
roeb
Jay Finke
Jay Finke
dannydoesita
Are you a Poulan Garden Expert? Answer questions, earn points and help others
