Question about Sony Ericsson K800i Cellular Phone
K800i Will turn itself off
This is a new set, but most of the time whenever it starts up and searches for network, or when I try to make/receive a call or receive a message it just goes off. I downloaded the updated software from the website, but no improvement. Sometimes I wanna smash it or just use it as a camera. What a waste of money. Can anyone help me with this???
  • magicsarab Jan 22, 2008
    I tried all that, but none of that worked. The phone is brand new! I took it to a technician, he said he fixed it, but a couple days later it did the same. it is like the phone is possessed or something!
  • 70 Answers
In make/receive/search time your mobile consume more power.
in that time the phone not get the needed power, so it switch off.
  1. Sol. Refix your sim and battery
  2. check your battery contacts to phone, it may loose contact, clean using a rubber on both battery and phone contact
  3. Check your sim contacts also
  4. Check your battery status, go to sony ericsson authorised dealer for check it used original battery some time you will get a duplicate battery,
Posted on Jan 17, 2008
Dish Box turns itself off every night and not back on.
C Dunn,
I can definitely provide assistance with this. Whenever our receivers do their nightly update, the receivers do enter standby mode. There is no way to disable this, but you can definitely setup an Auto Tune timer. This will cause the receiver to exit standby mode and tune to a channel.
To set this up, find a channel you want the TV to go to, and choose the time you want the receiver to turn on. Press record from the guide. Select 'Auto Tune' from the list, and select 'Daily'. This will set it up to happen every day.
If you have any other questions, just let me know!
Tommy Faust
DISH Social Media Representative
Nov 27, 2012 | DISH Network ViP622 DVR DTV Receiver /...
I have an LG 42LG70 42 in. HDTV LCD TV. Whenever I have my brightness setting below 40, my Dish DVR will no longer respond to its Dish issued remote control. If I turn the brightness anywhere above 40,...
Tries unplug,replug the DVR box an hour later.The box should reset itself and update it software.The box should work normal again.Not,call Dish Network to replaced the box,have intermittent problems.
Aug 26, 2010 | DISH Network ViP722 DTV Receiver /...
No network coverage sony ericsson k800i
how can get net work coverage in k800i sony ericsison mobeile phone
May 29, 2009 | Sony Ericsson K800i Cellular Phone
Red triangle on left hand top corner - K800i
hi
triangle means roaming if its a red triangle then your internet is turned off while roaming
go to options>mobile network> data services and select what setting you would like either on all the time, off, or off while roaming
solid triangle means extended network (coverage with another carrier that your service provider has an agreement with). some services might not work
blinking triangle is roaming (on a network with no agreement)...most carriers have simply disabled roaming entirely, you either get their network, or extended network to avoid additional charges. int'l roaming is different, not restricted. if you're near either of the borders, i'd say choose "home only" under network options to avoid int'l charges
Hope that helps
May 25, 2009 | Sony Ericsson K800i Cellular Phone
LG viewty switching itself off and not restarting until battery removed and replaced LG Viewty randomly switches itself off and won't switch on again until battery has been removed and replaced.
I have exactly the same problem! My Viewty just switches itself off whenever I send/receive text/calls. I can't even switch it on anymore without it turning itself off after less than a minute!
I have contacted LG, but they are not responding. Has anyone found a solution to this problem?
Nov 20, 2008 | LG KU990 Viewty
CANNOT RECEIVE PICTURE MESSAGES FROM T-MOBILE CUSTOMERS
hi
most networks want you to send a picture message before you can receive them, i know t-mobile and virgin both require you to send before you can receive picture messages.
could be the same on your network
hope that helps
Jun 05, 2008 | Sony Ericsson K800i Cellular Phone
Sony k800i configuration error
You need to get the Settings for Internet/Wap and MMS from your Network Service Provider. These settings are usually sent as a text msg. When you receive the msg. choose save or install on your phone. Or get the settings directly from their website. The MMS service doesn’t always work between networks.
"Beware of Geeks bearing gifs"
Apr 06, 2008 | Sony Ericsson K800i Cellular Phone
Network problem
try with following path
Main menu--->connectivity---->Mobile networks-->new search/select network/search mode/preferred n/w ..click on new search, it will automatically select the appropriate n/w... or else restore ur handset ( Menu>>settings>>master reset>>reset settings (default code :0000) )..it will solve ur prob.....
Oct 01, 2007 | Sony Ericsson Walkman® W880i Cellular...
Set turns itself on for no reason (and sometimes off)
on menu, pick customize, then set the video input sensor to off.
Dec 31, 2006 | Hitachi 43UWX10B 43" Rear Projection...
Sony Ericsson K800i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
