On this model, sounds like the clutches are bound up in the bypass feeder.
These gears are in constant motion with other gears in rotation in the copier.
The mechanical gears on the bypass feeder need to be disabled. The machine cannot be used. The work is involved in order to do this repair job.
If all else fails, Place a service call to Xerox for repairs before other gears get broken, then major problems can occur.
there is either paper stuck around a roller (3) that feeds the paper or you have a bad clutch, most mnfs use magnetic clutches at the rear of the machine or bypass that get a red rusty dust in them causing squeal. recommend xerox takes a look...sorry they are quite expensive hourly
How easy is it to replace the belt drive..and should I take it to a service/repair shop to have it...
(More)
How easy is it to replace the belt drive..and should I take it to a service/repair shop to have it done?
it says that they cannot proceed with the download because it says it has no valid digital signature...
(More)
it says that they cannot proceed with the download because it says it has no valid digital signature to verify publisher
printer will not print. A code keeps flashing. The letter L and the number 6 keeps flashing...
(More)
printer will not print. A code keeps flashing. The letter L and the number 6 keeps flashing alternately. What does this mean?
