Question about Hobart Food Mixers
How do you clean the sight glass on a Hobart 60 quart mixer?
SOURCE:
bigg t
  • 640 Answers
SOURCE: I need the manual for the Hobart 20 Quart Mixer
Hobart doesn't release their service manuals to the general public,however i'm a hobart tech and repair these mixer's often.If you need any help let me know.
Posted on Mar 07, 2009
bigg t
  • 640 Answers
SOURCE: what kind of paint should I use on my Hobart 20
Alot of people use house paint,but if you get a good primer and then an automobile spray paint such as 3m it works well.
Posted on Apr 28, 2009
asnowman
  • 788 Answers
SOURCE: reccomendations on how to move a Hobart H600 Mixer
I would use the 4 wheel platform dollies and ratcheting tie-down straps to secure it to the dollies.
I have used these to move pianos and other larger objects, but make sure that you secure the object to the dolly and get the best one with the biggest wheels that you can find. The bigger the wheel the easier the roll. Not sure how big your doorways are, but if you can use 2 or 3 dollies, that’s what I would recommend. Just make sure that you secure the load with ratcheting straps not just rope.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I have managed to answer your questions and have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot give this post a “FIXYA” (Two Thumbs Up) rating then please comment to this post and I will try to help you further.
I try to provide the best FixYa experience.
Posted on May 23, 2009
ginko
  • 19396 Answers
SOURCE: My mother needs a replacement bowl for a Model 4C Hobart Mixer
Hi.
The Hobart/Kitchenaid model 4C Stand Mixer was produced between 1961 and 1977.
This unit is now a vintage piece chased by collector. Parts dealers do not sell parts anymore for such an old model.
The parts must be purchased on the second hand and vintage market, best source is Ebay. Put 4c mixer or kitchenaid 4c to find parts.
The bowl is easy to find, it is part 4162158, regular retail price for replacement is $44. buy the glass one on Ebay, that will be the original one mounted on first models.
Here Ebay list.
Vintage KitchenAid 4c Glass Mixing Bowl Excel Cond!
VINTAGE KITCHENAID 4C MIXER WIRE WHISK ONLY
KitchenAid Mixer md 4C Complete with Bowl White
KITCHENAID MIXER 4.5QT S.S. BOWL FTIS MODEL 4C 4162158
Here also a forum where you can contact more Kitchenaid vintage appliances owners or collectors.
The dough tool is not even easy to find on Ebay. Try contacting Kitchenaid and see if they can give you a compatible part.
If they have the original one (unlikely) , then do not be surprised if part price is over $30.
If you find a 4c with tools for spares on Ebay , buy it, and resell the parts you do not need. The whole mixer with bowl and one tool is worth over $50.
The original owners manual can also be purchased from Kitchenaid/hobart
Regards.
KitchenAid Customer Service
Posted on Nov 13, 2009
  • 110 Answers
SOURCE: how to change oil in 20 quart hobart mixer and the
on a a200 there is no oil. this mixer requiers grease. if mixer is leaking oil it is because the grease is broken down .you have to pull tpo cover off mixer remove trans. parts clean out old grease clean all trans. parts reassemble put top cover back on .then make sure mixer runs in all 3-speeds before putting 1.5 cans of -47grease back in grease can be bought @any hobart office
Posted on Jan 09, 2010
How much oil does my H 600 Mixer hold ( Hobart in the Transmission
1 gallon of 90w Gear Oil -- can be purchased from AUTOZONE! Make sure when you have completely drained from the large drain screw from under the mixer toward the back of where the attachments go on but not part of the part that spins around known as the Beater shaft! Once you have drained out all of the oil -- from the top where the front screw attaches the head or cap of the mixer -- add the oil there and make sure you are watching the sight glass to see when it is at the HALF way mark in other words when the oil level (TIP: Use a bright led flashlight to shine directly at this sight glass to view level) reaches to the midway mark of the oval sight glass, THEN STOP! It is full! Carefully start mixer on 1st gear and then 2nd so on and so forth to make sure everything is getting relubricated correctly and slowly -- don't just go setting it on 3rd or 4th speeds as you want to baby the mixer when you just put in new gear oil
Hope that helps!
Jun 12, 2014 | Hobart H600 Stand Mixer
What kind of oil should I use in my Hobart 800 floor mixer? jdnwilk@juno.com
Hello Jdnwilk,
In a Hobart L800 you use 140 weight gear oil in the head and 90 weight gear oil in the planetary. You should start with about 160 ounces and check the sight glass and fill until in the middle of the site glass after oil settles.
Thank you for choosing FixYa.com
Mar 06, 2011 | Hobart Food Mixers
Oil capacity for hobart h600 mixer
128 FL OZ or to the line in the sight glass.
Mar 23, 2010 | Hobart H600 Stand Mixer
PLEASE HOW TO CHANGE OIL OF A HOBART MIXER H-600 C Cooper Lebanon PA
underneath trans. you will find a drain plug remove, drain oil,replace plug ck the sight glass @ this time if not clear would recommend replacing glass remove top cover where the front cover screw theaded into remove that is your fill hole. add new oil till you hit level line in sight glass,reassemble
Dec 31, 2009 | Hobart Food Mixers
What type of oil does a Hobart 60 quart mixer use?
a H-600 takes part#102973-71, thehl600 takesthe same just less. dont for get to vote tks. monomoy
Dec 11, 2009 | Hobart HL600 Legacy Stand Mixer
the motor protection board is doing its job.you should only use 1st speed to mix pizza dough.im a hobart technician and service these mixers all the time.let me know
Jan 27, 2008 | Hobart D340-6007 Mixer
Old hobart s-30 mixer oil
man you got an oldie but goodie mixer!im a hobart service tech for 8 years and have only seen about two dozen,unfortuantly parts for these units are exhuasted.as for the sight glass they do become cloudy over time and you cant determine the oil level.use a heavy gear case oil.the only way of telling is to drain the oil or if the unit is loud you should probably cange the oil.
Jan 20, 2008 | Hobart A200 Stand Mixer
Food Mixers Logo
140 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
Steve Allison
Steve Allison
Bruce Showalter
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
