Question about Hobart Food Mixers
Need service info for d obsolete Hobart model d3000 mixer gearbox.
    Top Expert:
  • Hobart Master
  • 52,781 Answers
Request the information directly from Hobart.
Posted on Dec 22, 2018
3 Suggested Answers
SOURCE:
  • 110 Answers
SOURCE: need circuit card for Hobart Mixer Model HL600C
ge is a recitml# and repost, there are 2 p.c.b.for that mixer 1 is a recipe timer for ml#134317,part#916560, the other is a standard timer part#916557, can be bought @ any hobart location, one would assume that the c on the model # stands for corrections. hope this helps, dont forget to vote, monomoy
Posted on Jan 10, 2010
  • 119 Answers
SOURCE: I need diagram of gearbox for Hobart d330 mixer
Parts manuals are available for viewing and free download at www.hobartservice.com
Posted on Jul 16, 2010
Testimonial: "I know,ust can't find them. If you could explain to me how, I would appreciate it"
I can't get the main shaft out of an A200 Hobart Mixer to service the lower bearing. Any advice?
Honestly, get someone in that knows Hobart mixers. The a200 is an amazing machine, but you will need to strip the entire gearbox apart to get to the bearings. Take this from someone who works for Hobart :)
Feb 19, 2018 | Hobart Food Mixers
What type of gear lube should I use for my Hobart H600 mixer?
Hi, btperduell
below is a copy of an e-mail from Horartservice.com. I searched the web forhours for the correct oil and could not find any info so I e-mailed Hobart. The Planetary is a different part from the transmission andthe sight glass on a M802 is for the oil in the transmission. The answer that Hobart gave is not an NSF oil. Ineeded the oil for the planetary section on a model M802. Even the directionssay that it is normal for a drop of oil to occasionally drip from the seal.That is where the dough hook attaches. I am in the process of researching the oil and Exxon / Mobildoes make a NSF version. I just need to find somewhere I can buy less then a 55-gallondrum. The above mixer only uses 6 ounces. Take care and stay safe Thank you Mike Hobart E-mail follows ============================================================== Mike, Hobartuses "EXXON SPARTAN EP-150 (6 oz)" in the M802 planetary. Hobart part #102973-13. This IS NOT a food grade oil. If you mixer is leaking you shouldhave it serviced. Service, parts , lubricants and information canbe obtained by contacting your local Hobartoffice in Pittsburgh@ (412) 788-5380. Steve Davis Field Engineer - Food Machines Product Service - Tech Support
b>
Jan 15, 2011 | Hobart HL600 Legacy Stand Mixer
Dec 23, 2009 | Hobart D300 Stand Mixer
Hobart c-100: how to remove gear shift plate???
parts are almost obsolete for that mixer
Oct 02, 2009 | Hobart A200 Stand Mixer
Need to buy a switch for the c-100 hobart mixer?
Hi. Hobart no longer makes or sells parts for the C-100 model. It's considered obsolete.
Your best bet is to locate a used restaurant equipment supply place and ask around. Sometimes these places keep old mixers for parts. Another option is to do a search on eBay, as there are several sellers that deal in obsolete parts. Failing that, a local electrician may be able to fabricate a new one or adapt some some other type of switch.
With a unit as old as this, it's important to maintain a good re-greasing schedule (once every five years), and your mixer will keep on delivering the goods for years to come.
If you found this solution usefull, please rate it as fixya. Good Luck! ricardok45
Jan 31, 2009 | Hobart A200 Stand Mixer
I need parts too
You could call hobart and see if parts are availiable,but i doubt it because its obsolete.Im a tech for hobart what are you looking for?
Dec 16, 2008 | Hobart A200 Stand Mixer
Problem with the 3rd gear on Hobart D300
Hobart won't give up service manuals The slide for your shift fork may be froze or corroded at top. The gear setups are fairly simple. The mainshaft nut comes off counterclockwise. The top gear has one way rollers with shims under the large washer. This gear assy must go back in the right way or you will break gears as soon as you start it.These mixers corode a lot at the top gearbox when they sit idle from moisture. Also check for broken gear teeth that may be jaming up he works. If you want to sell it let us know.
Dave at machinerysurplus@yahoo.com
Dec 11, 2008 | Hobart D300 Stand Mixer
Hobart mixer
Please be more specific of what part you need.Whats the problem with the mixer?Im a hobart tech and service these mixers often.
Feb 18, 2008 | Hobart A200 Stand Mixer
Food Mixers Logo
123 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
Steve Allison
Steve Allison
Bruce Showalter
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
