Question about Fisher Paykel EcoSmart GWL15
  • 76 Answers
Swith machine of, take top of machine, to one side you should see a clear plastic pipe that connects to probably a red object, either round or oblong, pull this pipe of and blow down it, then replace it, hopefully this will solve your problem.
Posted on Nov 27, 2007
My maytag neptune mah3000aww spins slowly then reverses, then spins slowly. will not reach regular spinning speed. What is the problem?
it could be a balance problem. Most machines are programmed to abort fast spin if the drum is unbalanced. This can be caused by too much in there, or possible the contents have clumped together somehow. Try a spin cycle only with an empty machine and see if it reaches full spin
Feb 18, 2015 | Maytag Neptune Washer Door Mah3000aww
Slow spin speed
Assuming you have reviewed the front panel options/settings verifying your spin speed is set to a spped above slow/low, the unit will wash forward, and reverse, and there are no error codes during your cycle, your most suspect part will be the door latch/lock assy. Part# 131763202. In some cases the final leaf contacts within the lock assy that make when the wax motor energizes do not make good contact. Pleazer Appliance...
Apr 11, 2014 | Frigidaire Affinity ATF7000E Front Load...
Kenmore 417.43142200 final spin is slow
obviously the timers contacts are bad so replace the timer.
May 16, 2017 | Kenmore 43142 Front Load Washer
Will not go into final spin
Just a Idea, belt is slipping this is why when it is empty it works on high speed when full its to heavy and belt slips
May 06, 2010 | Frigidaire HE 3.1 cu. ft. Extra Large...
It starts to spins slowly but never gets going
it is the moter or it can be the module
the moter has three windings
1 distrabute
2 slow spin
3 fast final spin
check brushes first if ok get expert in
Jun 27, 2009 | Washing Machines
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
Kenmore Front Loading Washer Slow Final Spin Cycle
I have exactky the same problem Replaced the drum and now it will not final spin, I touched nothing else.Can't figure what could be wrong,speed board too sensitive?
It worked fine before the bearing went.
Any ideas?
Mar 05, 2008 | Washing Machines
out balance are water still in tub will do that try cleaning out the pump filter under the panel at the bottom of the washer some have a big white looking screw you turnit remove filter if there water in it it will flow to the floor so have something to catch it with
Jan 26, 2008 | Kenmore 44102 Front Load Washer
Fisher Paykel EcoSmart GWL15 Logo
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
