Question about Mitsubishi Televison & Video
How to replace a color wheel on a 65 inch mitsubishi tv
SOURCE:
SOURCE: RCA DLP TV needs color wheel replaced
I used the internet and found others who had the same problem. Two individuals had a brief description on how to replace the color wheel in a DLP TV. Three small torque screws and a ribbon connector was all that was need for removal; once the access panel on the back was opened. I would guess that this process is the same for all DLP TV's, with some small variations!
Posted on Nov 30, 2008
SOURCE: 65 inch Mitsubishi replacement screen? (WS-65311)
I think I can help you out if you still need that screen, I have a new screen, both fresnel and lenticular lens in a frame for a ws-65411. contact me at jgrisz@comcast.net
Posted on Apr 16, 2009
demonicsaint
  • 160 Answers
SOURCE: WS-65513 65 in. Rear Projection HDTV Television: My 65 inch Mitsubishi tv turns off a couple of sec...
The power supply will need to be replaced.
Posted on May 07, 2010
CaptainHawk1
  • 345 Answers
SOURCE: My mitsubishi 65-inch dlp tv
It's either mirror hinge fatigue or dust on the inside.
Mirror hinge fatigue can be fixed by putting a solid color picture (white or gray works best from what I understand) on the display and letting it sit for 20 minutes.
If it's dust, someone is going to have to go in there and clean it out.
Also could be a defective micromirror device.
Try the first suggestion and if it doesn't work, you're going to need a technician to take a look at it.
Posted on Nov 23, 2010
gopakumarg43
  • 76060 Answers
SOURCE: TV is 73" DLP Mitsubishi.
Hello
There are tow reaons for this fault. The first one is with the colour whell as you mentioned here. The second and most importan one is with its bulb itsef. Colour wheel won't cost too much. Just replace it first and see whether it helps you. If not, bulb may have to be replaced.OL
Posted on Jul 31, 2011
I have a Mitsubishi 65" dlp TV and the picture is green and yellow with no reds or magenta's so would that mean i need a new bulb or does it have something to do with the color wheel
It means that the color wheel or it's encoder is not properly syncing with the controller. It is therefore blanking the DLP chip on the red and blue sections of the color wheel. Clean the color wheel motor and encoder disk, lubricate the motor. This should correct the problem. There may be dirt in the opto-coupler that is reading the color wheel. Be sure to clean it with a vacuum and small brush. Regards.
Nov 28, 2015 | Mitsubishi WD Televison & Video
How do I fix the color? We replaced the dlp chip and since then we see blue lips and brown grass/trees.
Your color wheel is not calibrated properly. It needs to be re-aligned with the colorwheel. That will require access to the service menu. Service manual eprom result list ElektroTanya Service manuals and repair...
Here is the service manual which will show you how to re-align the color wheel.
Feb 24, 2015 | Mitsubishi WD65737 65" DLP TV
Mitsubishi 65 dlp
SOUND LIKE A BAD COLOR WHEEL...HEAR A LINK TO SEE IF THAT THE SOUND YOU ARE HEARING ....http://www.youtube.com/watch?v=hUiYRqrNxxU
Dec 24, 2013 | Televison & Video
Buzzing/humming noise won't stop. Lamp was replaced a year ago. This just started and the noise is near the lamp. The noise won't stop while the TV is on and lasts for a minute when the TV...
If its a DLP with a high pitched or even fan like sound it is the color wheel--Mitsubishi does not sell them as a part---you would have to replace the entire light engine (expensive and may not be available any more on a older set) .
Nov 08, 2012 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
No picture. Loud whining noise from back of tv. Audio is working
your color wheel has gone bad. not a diy project. you need professional help.
Mar 08, 2010 | Mitsubishi WS-65903 65" Rear Projection...
MY TV COLOS GO AWAY GOES DARK CLOUDY KIND OF GRAYISH
Check your color wheel sounds like that is going bad. 90% of the time the color wheel is the culprit in this cause. You will need to remove the back panel to get the to color wheel. You will see 7 different plastic adjustments. You can also order this part online at mitsubishis website
Apr 10, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Televison & Video Logo
63 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
