Question about Nikon Cameras
D70 mirror lock up
Mirror inside is lock in upper position and it doesn't go down. Reset doesn't do any good and "mirror lock up" option is not accsesible.
Thanks Mike
In nikon d 70 the funtcion mirror lock-up is unactivated. plz help me. shutter is locked up.
Posted on Apr 25, 2010
I'm looking for the source of this same problem. I was able to get my d70 unstuck by:
1. Set to full manual mode.
2. In the menus set mirror lock up to yes and then press shutter release.
3. Turn camera off and then back on
Hope this helps you!
Posted on Jun 10, 2008
I have a Toyota Revo GLX, model 2001 with powered side mirror. From stored position (folded on the side of the window) to open position ( when you are going to use the side mirror), there is a clicking and...
Hi MVN, Seems that the washer is from the securing hollow mount. There should be a nut somewhere inside too. The mirror is electrically operated not hydrolic. The mirror will probably break if you try to remove it from the housing, but as to save it you will have to do so anyway, you may as well try. If you are successful, you can reattach it using double sided mirror tape, but make sure it is a good quality tape. Adjust it to the maximum and insert a flat blade between it and the mounting and try un-clipping it. If it does not break you should be able to replace and lock the housing back in place, but it will be difficult. To replace the mirror you will need to remove the door panel and the small cover on the inside of the door adjacent to the mirror mount. It clips into place and is gently levered off. Inside are three screws holding the assembly in place. Disconnect the electrics inside the door panel and then remove the screws. Fit back the replacement and reassemble. Regards John
Aug 18, 2012 | Toyota Cars & Trucks
Craked right side mirror
the glass is serviceable. Please rate, thanks
  1. Position the exterior mirror glass in the full DOWN position.
  1. Using a suitable tool, release the locking tabs from the exterior mirror motor and remove the exterior mirror glass.
    • If equipped with heated mirrors, disconnect the electrical connectors from the exterior mirror glass.
May 24, 2011 | 2006 Ford Escape
Nikon D2X - How do you lower the mirror if it gets locked up by mistake ? Had an err message on the upper view screen, tried the repair from this site, by tapping the front leftside of camera front and...
Normally, you can manually lock-up the mirror for the purpose of cleaning the sensor. To do this, you need to connect the camera to the optional EH-6 AC adapter. If after removing the lens and inspecting the mirror, you cannot gently nudge it back down (do not touch it...use a cotton swab) then you'll need access to the EH-6. If you don't have one, possibly a camera store near you would have one and be willing to let you plug in your camera so you could try to access the mirror lock-up function in the set-up menu.
Nov 08, 2010 | Nikon D2X Digital Camera
I have a D70 Nikon, I took a pictue and the mirror locked up and the lcd says error. the mirror won't come back down.
most likely a jam. go get it to a nikon store or something. you shouldn't ever touch the mirror if possible. the best thing to do is to get it fixed in it's CURRENT condition.
Jun 25, 2009 | Nikon D70s Digital Camera
I see a spot on every image taken with my Nikon D70
This is probably dust on the sensor.
You can clean this yourself or you can send the camera to Nikon.
If you want to see what you have to do, search for "nikon d70 sensor cleaning" on the internet.
There are instructions and videos to help.
It involves taking the lens off and locking up the camera mirror using the menu option.
Then either blow it off with a camera blower or clean the sensor with a cotton swab.
I did this myself on my D80, it is not hard but you have to be careful.
Feb 02, 2009 | Nikon N70 35mm SLR Camera
Mirror lock
Possibly the shaft has jammed. Follow this link for a source of good information:
From their files:
The locking knob has a gear on the inside end of its shaft. It engages teeth on the outside edge of a large metal disk connected to the mechanism that locks the position of the mirror on the central baffle tube. Rotating the locking knob one direction rotates the large disk to tighten the collet on the central baffle. Reversing direction loosens it.
The teeth do not extend all the way around the large disk. So sometimes the locking knob gear jams to a stop before the lock is fully engaged. Soon after the GPS scopes first started shipping Buck Harley discovered that in such cases you can remove the locking knob with its shaft and gear, then reach in and rotate the large disk with your finger. Replacing the locking knob will now allow sufficient rotation to fully engage the lock. If you happen to move the large disk in the wrong direction, then just repeat the process and move the disk in the other direction.
You don't need to tighten the lock down hard. Just a little snug is enough. You should not attempt to use the coarse focus knob while the mirror is locked. Damage to the focusing mechanism could result.
This design is intended to precisely hold the mirror position. So, yes, it is meant to allow effective use of a separate guide scope by eliminating mirror flop when in the locked position.
May 26, 2008 | Meade LX200GPS Telescope
A spot appears in same location on every picture
take the lens out and blow air inside the camera and on the inside part of the lens.
Jan 10, 2008 | Nikon D40x Digital Camera
Mirror Locked in Up Position
When you say you put in a new roll of film, did the camera advance the film with the mirror locked up? Have you tried triggering the shutter few times to release the mirror? If that doesn't work, open the back of the camera. Turn the film take up spool in one direction...that should release the mirror down. Turn it also in the opposite direction. If that doesn't work, reach inside the lens mount opening and pull the mirror (very very gently) down. Don't force it down if it doesn't want to go. Sometimes that releases the mechanism that freezes from sitting idle for too long. It is always a good idea to take the camera out and triger few frames every couple of months to keep things lubricated. Let me know if that fixes it. AJ.
Sep 03, 2007 | Nikon N70 35mm SLR Camera
Scratch appears in photo's
The nice curvy pattern looks like a hair but I supposed it could be something else. Are you sure you've cleaned both the front and back of the lens?
Sep 19, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
Cameras Logo
929 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
