Epson POS TMT88IV Thermal Receipt Printer Logo
Posted on Aug 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Setting up two printers on the same pc
I have two Epson TM-T88IV printers and i want to connect both to the same Windows XP SP2 computer. One via parallel and the other via serial. Only the parallel one works. the pc can't even detect the serial one.i need help
HyeProfile
Level 2:
  • Expert 35 Answers
  • Posted on Aug 04, 2009
HyeProfile
Expert
Level 2:
Answers
35
Questions
0
Helped
40919
Points
100
You need to manually setup the serial printer, as it probably isn't getting detected via plug n play:
  • Go to Start Menu\Printers & Faxes
  • Click on the 'File' menu and choose 'Add Printer'
  • Click next at the wizard, then select 'Local printer attached to this computer' and leave the 'Detect Plug n Play...' box unchecked, click 'Next'
  • Choose the correct serial port (either COM1, COM2, etc), click 'Next'.
  • Choose the correct printer manufacturer & model to install the correct driver, click 'Next'.
  • Print a test page, just to make sure it's working
How can I set up Wifi or bluetooth connectivity?
Hi, I've looked at all TM receipt printers no such model. You may need to purchase the interface board to make it Wi-Fi or Bluetooth. If you can provide more info maybe I can help you. How old is the printer? These things change often, New technology it's outdated the day it hits the shelves. Not really but you get the gist.
What can i do to enable my printer's beep in windows 7
Have you installed the windows 7 driver obtained feom epson comany?
support.epson.com
What should I do, to not have much paper loss?
can u try printer with standalone pc
or with another single pc
1helpful
2answers
I am using Epson TM T81 thermal printer and it is showing status USER INTERVENTION REQUIRED , printer is not printing document. I uninstall drivers and install it again it works but whenever I restart the...
Sir/Madam
i suggest You download Epson Printer Driver From official Epson Printer Website and Perform Below Following Step Mention On Epson website on Below, i hope You Fix Your Epson Printer problem,
1. About this software This package includes the following two software programs to use with an EPSON TM-T81 printer. 1) Windows Printer Driver This driver is a Windows Printer Driver for the TM-T81 printer. This driver makes it possible to print from a Windows application.
2) StatusAPI StatusAPI is a program that works in conjunction with the TM-T81 printer driver. It offers an Application Program Interface for obtaining the printer status whether or not the printer is printing. This API makes integrating printer status handling functions with applications more simple. For detailed information, please see each reference manual. The driver operation has been verified with the following operating systems. Windows 7 Ultimate SP1 32/64bit Windows Vista Ultimate SP2 Simplified Chinese 32/64bit Windows XP Professional SP3 Simplified Chinese 32bit Windows Server 2008 R2 Enterprise SP1 64bit Windows Server 2008 Standard/DataCenter SP2 Simplified Chinese 32bit Windows Server 2008 Standard SP2 Simplified Chinese 64bit Windows Server 2003 R2 Enterprise SP2 Simplified Chinese 32bit Windows Server 2003 R2 Standard SP2 Simplified Chinese 64bit Windows XP Embedded 32bit SP2 Windows Embedded Standerd 2009 32bit Windows Embedded POSReady 2009 32bit This driver is not supported by Windows 95/98/NT/2000 and Windows XP 64bit. EPSON IM series PC or IBM compatible PC Supported Printers EPSON TM-T81 The printer driver operates regardless of the pritner firmware version. 2. Supplied Files APD_415bSC_T81.zip : Printer Driver,StatusAPI installer with manuals Refer to the installation manual APD4_T81_Install_SC_RevE.pdf. 3. Remarks - For detailed information, please read each manual that is created by the installation. -When an error message is displayed during installation, the following procedure may enable to recover from the error. 1) Specify the uninstall option, and execute the installer "APD_415bSC_T81.exe /uninstall". 2) Remove the error factor.
3) Execute the installer "APD_415bSC_T81.exe". -Characters may not be printed correctly when using Easy Print of Windows Server 2008. For detailed information of this problem arising from the operating system, see the following web page provided by Microsoft Corporation.download epson biz com
Or If You Still Need Epson Printer Help Then Follow Us On:
Epson Printer Support
1helpful
Printer not responding message on epson TM-T88iv
You must first uninstall the printer from the Control Panel. Reboot the PC. Then reinstall the printer with the printer NOT connected. Then connect the printer and allow Windows to detect the printer and load its drivers. When you get a message in the right bottom corner of the screen "The new HW has been installed and is ready for use" then fireup the word processor and set this printer as default printer and start printing. All the best to you.
1helpful
2answers
Epson TM-T90 wont work with USB plug
I have the same problem...Epson does not work with a parallel to usb cable or adapter. If you still want to use this printer you will have to use the parallel port or change the interface on the printer to USB.
1helpful
What do I need to hook up TM-T88IV to my computer to print out receipts?
Well according to EPSON the ways you can connect your printer to a computer are RS-232C, IEEE 1284 parallel; RS-485; high-speed USB; 10/100Base-T/TX; wireless. However the way they get you is you have to buy the interface from them. Contact EPSON and see what the cheapest one is. If you're only using it from one computer just a simple parallel cable will do the trick. If you live in the Washington DC area feel free to contact me and if you send me a picture of the back of the printer I can tell you what kind of connection it is. I'm at http://www.inovagent.com
Tm t88iv print slow
This is definitly a driver problem. Change the driver to one that is compatible with Win XP.
1helpful
Tm-t88iv epson made prnter driver for win 2003 server r2 std
Epson POS driver will not install on a Win2K3 machine due to the InstallShield Wizard w/c checks if your running XP/2K or not.
Download the driver from EPSON POS site & extract the contents first on an XP machine.(Installing the driver will create a C:\Epson folder where ACTUAL driver is extracted).
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
