1995 gmc safari
I beleive i have a bad relay or something. my battery will drain overnite, not during the day. battery tested good. every time i plug in battery post of a morning there is a 'click-click' inside the vehicle, sounds like coming from inside the vehicle.what's up do you think?
  • slick67 Nov 26, 2007
    if a relay, where under the dash is it?
    Master:
    Sergeant:
  • 482 Answers
The hood, in a box, big fuse
Posted on Nov 26, 2007
  • farren wadley
    farren wadley Nov 26, 2007
    Did this help? Under the hood
How can I tell if my ignition harness is bad?
Battery is dead or starter wires are not making proper connection. Check the starter wires first.
Aug 17, 2014 | 1995 GMC Safari
Battery last 3 days dead after that
with a multimeter test the voltage from alt to bat should be 14.2 volts test battery after a charge should be 12-13 volts not disconnect negative from battery and put your multimeter on fusable 10 amp and do a draw or drain test plug the black cable from the multimeter to the battery and the red cable from multimeter to the cable neg black on the car side cable unplugged from battery make sure keys are out of the ignition and the doors closed and nothing on in the car you should see .05 mv to .03 mv if you have more after a 30 mins test or 1 hour test then you have to find the drain on battery to find this you take out fuse at a time to see if it chages repeat not all the fuses at once 1 at a time
Mar 10, 2014 | 1991 GMC Safari
How do I change the fuel relay in a 1995 GMC Safari Van?
Fuel relay is usually under the hood in the fuse box just get a new relay and change it out. It's usually a small black box looking thing inside the fuse box . But you can use another none good one to check to make sure it's bad before buying a new one. Hope this helps.
Apr 11, 2012 | 1995 GMC Safari
1995 safari fuel pump will not work unless directy wired to battery.
you have an incomplete circuit on your wires connecting items mentioned, test light trace it, poor contact on connectors.
Feb 19, 2012 | 1995 GMC Safari
My 98 lumina has a constant power draw from somewhere. I just replace the battery and had the alt tested (it was good). I have to jump the dang thing every morning but if I drive it enough during the day...
The alternator may charge fine but could drain the battery through a bad diode,have you checked the alt for a bad diode?Disconnect the battery positive cable.Put a regular 12v test light between the battery positive post and the positive battery cable.If the test light is bright you do have a drain,if dim it is OK.A dim light may mean the drain is internal in the battery.If you do have a bright light remove a fuse ,one at a time from the fuse box until the light goes dim.Once dim you have identified the bad circuit.If removing all fuses do not dim the light,disconnect the alt charging wire at the alt,if that dims the light,then you do have a bad diode.DO NOT create a drain(bright light) when checking for the drain by turning on the key or opening a door/trunk etc.
Also,do an overnight battery check by disconnecting the battery overnight,if things are fine the next morning after the battery was disconnected then it is a drain in the vehicle,if the battery is dead even after being disconnected overnight,,then the battery is bad.
Jun 15, 2017 | Cars & Trucks
My car is draining the battery. battery is new and altenator is good.can it be a bad belt causing that promblem? this will happen about five days that the car will be working good
The belt can slip if the tensioner is weak .If you here a squeal when you accelerate,its a good possibility. The Alternator can drain the battery,even if it is charging the battery.If a light is on when the car is parked,such as a door ajar,glove box light on,trunk light on,any thing that's on a hot citcuit not controlled with the ignition key,will drain the battery in a few hours or overnite,or a day or so.
Sep 17, 2010 | 1995 Lincoln Town Car
Where is the fuel relay on 1995 gmc safari
Located under the hood you will see a relay box(plastic) unclip the cover and walla should be listed as to what fuse/relay is what on the inside of the cover, generally there are more then one of the same relay's which makes testing it a breeze...just remove the twin relay and put it in the fuel pump relay connector to see if the pump works.
Hope this works!!!
Jul 20, 2010 | 1995 GMC Safari
Something slowly drains the battery
Have you alternator tested it may not be putting out the needed amperage
Jul 17, 2009 | 1995 GMC Safari
Power windows on 1995 safari just stopped. new motor was installe
check the fuses most of the time located under the driver side dash
Feb 26, 2009 | 1995 GMC Safari
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
