SOURCE: Have an invacare patriot LX4. Unit takes full
Check to see if the scooter is in freewheel mode. To know if the batteries are bad you need to charge them for 10 - 12 hours and then have them tested with a load tester.
SOURCE: Blinking charge light on Invacare Zoom 300 scooter
Can you try another charger ?
Is it a onboard charger ? if so they do go wrong, Are they supply MK batteries ?
Check the leads from the charger connection socket to the motor controller board.
Regards
GeWiz.
SOURCE: I have an invacare scooter that doesn't work. Can
mcdevito75 here, It could be the battery--ies need re-charge or replacement, online at Invacare.com they can help out, or almost any Medical Supply store in your area.
SOURCE: mobility scooter lights wont turn off
It really can only be one thing. Somewhere on your scooter is a switch for the lights. Try turning it off. If that doesn't work the switch is faulty
