SOURCE: Whirlpool gas dryer. Only few min.( less than 5min) heat work.
there is a thermal fuse inside the dryer it is a one time fuse also there is an ignitor that could be bad
If you are having problems with your
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly.
if
you dryer is gas check out this gas
no heat
tip....
If you have an electric dryer, you can
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip...
heatman101
