Question about Bosch Washing Machines
My machine is not coming on have check the socket and put new fuse in plug but none of the lights on the front are lighting up It's a Bosch Maxx WFL2260uk/04 worked fine last time I used it
SOURCE:
  • 142 Answers
SOURCE: Bosch Maxx WFL 2260 not draining - nothing in filter - help?!
sounds like a simularproblem i had, a 5cent piece got caught in the drain solenoid (just between the drum and solenoid) , i had to lift up the front and spin the drain pump fan, on empty, then disassemble and clean pump assy and remove 5cent piece, hope this helps.
Posted on Jan 25, 2009
SOURCE: washing machine went bang and wont work. The plug fuse is fine and the washing machine light comes on but it wont work
Changes are you broke a "drive belt".
It snapped causing the noise.
Lift the top up (easy if you pry a bit on each corner).
You will see the broken belt.
Remove the old belt and take it to a shop to make sure you get an exact replacement.
Threading the new belt can be a tiny bit confusing but it will soon become obvious.
It is like the "fan belt" in a car.
Posted on May 27, 2009
beltronic205
  • 1479 Answers
SOURCE: Bosch Maxx - softener not dispensing into machine
It blocks very often , give it a good clean..remove soap dispenser to do so
Posted on Sep 28, 2009
  • 228 Answers
SOURCE: Bosch Dishwasher Maxx classixx Model S9H1B
look carefully at operating buttons they will have 2 marked with a line with dots at either end, open door press and hold these 2 buttons usually 2 and 4 as from left too right, turn on keeping fingers on these buttons after a few seconds end light will come on turn off at main switch then back on again should work after that.
Posted on Dec 15, 2009
  • 58 Answers
SOURCE: HP G60-230US lap top won't turn on
This issue could be due to presence of static charges or internal hardware malfunction of the notebook. To isolate the exact cause of the issue, perform the steps provided below.
Step 1: Hard Reset
To perform a hard reset, please follow the steps listed below:
1. Unplug the AC adapter from the notebook PC and remove from any port replicator or docking station.
2. Remove the battery from the notebook battery compartment.
3. Press and hold down the power button for about 20 seconds.
4. Insert the battery and plug the AC adapter back into the notebook PC.
5. Press the power button to turn the notebook PC back on.
This will discharge the static charges from the notebook. Now turn on the notebook and check for the issue. If the issue persists, then remove and reseat the memory modules of the notebook and check for the issue.
Step 2: Remove and Reseat the Memory Modules
You can refer the service manual provided below for information to remove and reseat the memory modules of the notebook.
http://h10032.www1.hp.com/ctg/Manual/c01602064.pdf
Refer page no: 52 & 53
NOTE: PDF manuals require the Adobe Acrobat Reader for viewing and printing.
If the issue persists after the above steps, then this could be due to internal hardware malfunction of the notebook and requires a detailed onsite diagnosis by a service technician. If your notebook is covered under HP Standard Warranty, then I would request you to contact HP Support to get your notebook repaired under warranty.
I believe the information provided would be helpful to isolate the issue with your notebook.
Posted on Jun 07, 2010
What is error E:00 in Bosch maxx 6 washing machine?
error E:00 in Bosch Caroline, Could not find anything pertaining to this Bosch code. You may be can contact Bosch at last link posted or download manual.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Identify Bosch Washing Machine Error Codes
How to Identify an Error Code on Bosch Washing Machine
Washing Machine Error Codes Front Load and Top Load Washers
Download instruction manuals
Apr 02, 2016 | Bosch Maxx 6 WAB28260GB White 600 mm...
Why is my bosch maxx classic frontloader washer tripping the safety switch in fuse box
hi rachel, there's a bad earth in the machine some where,things to check wiring to the motor, check the wiring it's self, any circuit boards, if they are all ok the programmer could be shorting out hope it helps
regards
shaun
May 17, 2012 | Washing Machines
Does anyone know how to check a fuse in my Bosch Maxx 1000 washing machine??
Try it in a different socket as it may not be the machine. The machine would have been factory fitted with a moulded plug, lift out the middle section and try a new fuse. If the unit failed after filling then possibly you have a short on the wash heater..you could verify this if you get power by setting a cold cycle or rinse and see if if completes it. Please also check that the consumer unit (main fuse box) has not been triggered.
Nov 26, 2011 | Bosch Washing Machines
I have a Bosch wkm 41 maxx classic front loader that is completely dead. Got home from a camp trip yesterday, did two loads, and then wouldn't do a third. No lights, no sounds, completely dead. Any...
Hi Simon from retired Englishman in SW France,
Check that the washer supply is OK using another item - a kettle for instance. If it's not check your breakers/fuses. Reset/replace if necessary and if the same thing happens, or if there was nothing wrong with the breakers/fuses in the first place, sorry but with such a fault it is virtually impossible for anybody on this forum to remotely guess what could be wrong with your washer. It could be internal wiring/plugs sockets, control panel switches, control PCB.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 25, 2011 | Washing Machines
Bosch maxx wfl 1300 washing machine that wont start.
hello could be brushes on the motor. there are 2 black clips that sit on the motor after time these whare down just slide them out and slide new ones in good luck
shaun
Jul 21, 2009 | Bosch Washing Machines
Bosch Maxx (ref WFL 2450). stopped during wash and switch on
Remove the front lower panel, screws underneath. Drain off water. Be prepared for more water. Check filter for clogging. Sometimes when the load is unbalanced & the machine cannot adjust the load it stops. To avoid this make sure your wash is mixed with big and small clothes.
If this does not work remove the rear panel & check belt, should have half inch ‘give’. Still not good, remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes, if it is any shorter than 5mm replace brushes.
Apr 01, 2009 | Bosch Washing Machines
Bosch Maxx lights on, hit Start as normal but nothing happens. After a while it goes back from Active to Ready flashing.
First question is does the display light up? If so then does the door lock? If the door is locking then the fuse for the washer that is on the back of the dryer hasn't blown. However if door won't lock, then check the fuse to see if it is open. This is a 208/240 volt washer and the display is the only part that doesn't need 208/240 volts. If fuse if find, then check the water screens in the fill hoses and clean them. This may be more of a control unit issue having failed, Hard to tell without knowing age of unit. Hope this helps
Jan 28, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Maxx WFL 2260
My drum stop, then I put in new carbon brushes. It works very good in 2mouth, now it stop again. Wht can be problem?
Jan 17, 2008 | Washing Machines
Washing Machines Logo
21 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
