Question about Kenwood VR-506 Receiver
Kenwood VR 208
When I turn the Receiver on, the red standby light blinks and then the receiver turns off. I'm told it might be the speaker wires. This system is about 10 years old. Please help.
Re: kenwood VR 208 - Kenwood VR-506 Receiver Audio & Video Receivers
It works sometimes, mostly the volume bottem
Posted on Sep 30, 2010
0 characters
3 Points
Kenwood vr-405 turns on only momentarily and then shuts off
your receiver has a bad audio output ic.replacing ic will take care of the problem
Apr 10, 2010 | Kenwood VR-405 Receiver
Kenwood VR-509 Receiver won't power up...
Check all your speaker wires for shorts, especially behind the amp, doesn't take much for something to throw a spanner in the works, like when cleaning house and moving stuff around.
Oct 03, 2009 | Kenwood VR-509 Receiver
Audio Receiver shutting off
check your speaker connections you have a short or wires touching eachother
Mar 14, 2009 | Kenwood VR-406 Receiver
I have a vr-255 receiver and the power light flashes
Hi Willie,
If the standby indicator is blinking that just means that the speaker wires are short circuited some where. Make sure all of the wires are intact, unplug everything starting with the power. Then you will want to make sure all wires going to the receiver are not kinked / twisted / or exposed. If all wires look good, plug everything back in and power on the unit. you should be good to go.
Oct 23, 2008 | Kenwood Audio & Video Receivers
Kenwood VR-405
Hi changeman5 Have you tried to do a full reset on the unit. Disconnect from the wall for 24 hrs. Then try again. If the problem persists, it may have power supply issues, or a DC offset problem shutting it down. If you are game, I could talk you through some more diagnostics...
Apr 01, 2008 | Kenwood VR-405 Receiver
My Kenwood VR-209
your speakers wires are touching together. this system has a protecter so you don't blow out the amp. the blinking is how it lets you know that
Jan 28, 2008 | Kenwood VR-209 Receiver
Receiver standby light,no power
WOOHOO!! I fixed this issue... same problem as everyone else has mentioned... to reset the Kenwood VR-606 receiver, unplug the unit. Hold the power button down and while holding the power button plug the unit in.
Say a prayer...
Then press the power button.
My display isn't working, but my speakers are working, and that's really all I care about right now... good luck to others!
Jan 18, 2008 | Kenwood VR-606 Receiver
Kenwood VR-307 Receiver standby light blinking
Hello, sorry to say this, but there is a hardware error. Possibbly something is wrong at the output stage. Please send it to tech for a repair. But first disconnect the speakers and then try to turn it on. If there is no change the error is still present. Best regards. Arpi
Jul 17, 2007 | Kenwood VR-307 Receiver
Kenwood VR615 turns itself off at medium volumes
I also have the same problem, it is really annoying... anyone have any ideas.... please help!!
May 21, 2007 | Kenwood VR615 Receiver
Kenwood VR-506 Receiver Logo
409 people viewed this question
Top Kenwood Audio & Video Receivers Experts
Level 1 Expert
Level 1 Expert
Are you a Kenwood Audio and Video Receiver Expert? Answer questions, earn points and help others
