There is no way to manually close that screen, there are several motors that operate a gear system that travels the unit out of the slot and raises it. If you can connect it to a good 12 volt source, you may be able to reset it unsing the small pin hole reset button on the left side of the two push buttons on the bottom.
SOURCE: how can i get my kenwood kvt-512 or kvt-512
This is basically a hack. Type into the web address bar http://www.dvdhacks.co.uk/ enter model number then follow instructions
SOURCE: Cant remember security code for Kenwwod KVT-512
try 00000 or 11111
they are the factory codes , if you didn't change the numbers
SOURCE: how do i bypass the parking brake to watch video
You will have to connect the pink parking brake wire to the black ground wire.
SOURCE: I need the site for kenwood kvt-512 update
try this I use this for getting user manual or leave them a question Good Luck!!!!
Techman
http://www.kenwood.ca/Support
