When we plug anything into the av1 we loose colour
New tv had for about 4months then all of a sudden when you use the av1 we loose colour it goes to black and white we use the av1 for video and dvd player if i record on the video and take the tape to another video player it is in colour can you help me
  • sharnie Dec 02, 2007
    thanks for trying but we had already checked those things we have since re checked them and still havent been able to get colour
  • drewdavis96 Mar 29, 2009
    My problem is the same with the same tv. I posted a new problem as well for this
  • 121 Answers
Check to see if the cable is properly connected. Both on the TV, Video and DVD points. If it's a SCART, does it have a small switch on it? Also check settings to see of there might be a PAL/NTSC issue.
Posted on Nov 26, 2007
I have the 3 RCA red, yellow, white cables on back of dvd and to tv. Video only plays when I select video 1 under the input. When when I select video 3 only sound and no video. What else can I try?
Sounds like from the symptoms that you have plugged the white and red cables into AV3 input on the back of the Teleivsion and plugged the yellow cable into AV1 on the back of the Television.
Check the cables are all plugged into AV1 input ports on the back of the Television. Red and White go into the Audio inputs and Yellow goes in the video input. Also make sure you have not plugged cables into component inputs on television look for AV1 in on back of Television .
Mar 08, 2015 | RCA Televison & Video
Trying to hook up dvd player to a philips 27ps55-s121. I cant get it to show up on the tv screen. I dont know what channel the tv needs to be on to show the dvd. and i am unsure where what plug (cable)...
Connect one end of the VIDEO
(yellow) CABLE to the AV1 in VIDEO
jack on the back of the TV. Then connect
one end the AUDIO (red and
white) CABLES to the AV1 in AUDIO
L and R(left and right) jacks on the rear
of the TV. Connect the other end of the cables to the appropriate color on the DVD player (yellow to yellow etc.)
Press the CH + or – buttons on the
remote to scroll the channels until AV1
appears in the upper left corner of the
TV screen.
Slide the TV/VCR/ACC switch to
the VCR position.
Insert DVD into player and press PLAY.
Aug 23, 2010 | Philips Televison & Video
I have a nintendo64 and im trying to connect the red white and yellow plugs to a vizio HDTV I dont know where they go in tv av1 av2 or component? Help
You need to plug them into the AV1 or AV2 plugs, they are colour coded so you know which lead goes into which socket.
Hope this helps
Aug 08, 2010 | Nintendo 64 Console
Trying to hook up a PS3 to a regular older TV (Zeneth). What do we need to make this work
hello just the black lead that has 3 coloured jack plugs on the end and scart block. on the tv at the back there might be 3 scart sockets av1 av2 av3 or e1 i'd connect it to av3 good luck
Jul 17, 2010 | Sony Playstation 3 (PS3) Console
My Samsung LCD TV slowly flahses colours, each about 2-4 seconds
your lcd is in test mode. you may try off the power. press and hold menu + source + power on.
this should go back to normal mode.
Apr 01, 2010 | Samsung LA40M81/BDX 40 in. LCD TV
Sanyo 68cm. AV1 is Black and White. AV2 and normal Tv is OK
the two AV1 and AV2 have different inputs on the IC,
the first port has a disconnection,
take your tv for a check up
Mar 20, 2009 | Sanyo DS13204 TV
Vizio 50'' Plasma AV1 & 2 Ports Unresponsive
Put off the TV Using the remote .Then unplug the TV 's power line from power source.Allow this for Just Over one minute .Then plug back the powerline and your TV should be okay.
i had the same problem with wii and this fixed it .
Nov 26, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Unable to connect philips dvd recorder/vcr recorder to philips flat screen 19pfl4322 tv. HAVE AV 1 AND AV2 ON FLAT SCREEN TV BUT RECORDER WILL NOT GIVE MENU PICTURE. COAXIAL CABLE ATTACHED TO VCR AHD...
make sure that av 1 out on the dvd go into av1 in on the screen and av2out goes to av2in onto the screen.make sure the cable is not av on the tv remote till you find it. same with the vcr remote
Mar 31, 2008 | Televison & Video
TV Akai CT29X4AV
Have tried checking if the Power Plug is fitting tightly in the Power socket? Could be that it is loose?
May 27, 2007 | Akai CTS2550 25" TV
Televison & Video Logo
305 people viewed this question
Top Televison & Video Experts
