Question about Philips (DN4S2S05F/17) (5 Pack) (DN4S2S05F17) DVD-RW Storage Media
Philips DVD+-RW DVD8631 will not recgonize or burn blank DVDs
To whom it may concern,
I've a problem with my Philips DVD+-RW DVD8631. It will not recgonize blank DVDs, but will play regular DVDs, CDs and will burn blank CDs. I've tried many times over to update the drivers and anything I can think of on the software side. I've also gone and deleted any and all burning software that may have caused a problem and reinstalled only the OEM installed Cyberlink PowerDVD and DVDShrink and DVD Decrypter. These ones have been on my computer for a while so I know they aren't the cause of the issue. The drive reads blank DVDs as CDs with 0 bytes free and 0 bytes used. I've even tried to find a solution on and all I got was another link to the same driver I've installed over and over. Is there anything else I can do short of buying a new drive? Thanks.
  • 4 more comments
  • Degenerate Dec 10, 2007
    I have the exact same problem except with my Sony DRU-810a
  • mainebear2 May 03, 2008
    Same issue here. I have a Philips DVD+RW-D28 and the drive does not recognize blank dvd's anymore after instally Dazzle DVD Recorder. I can burn and play CD's, play DVD's but still can not burn things to DVD's. Shows up as 0 bytes just like what the other person on here state. I have uninstalled Dazzle but the problem still exits. This drive only reads +R not -R
  • hotest Sep 02, 2008
    I have the same problem. My Philips DVD +- RW DVD8631 does not recognize blank DVD or burn a DVD. I have tried Memorex DVD -R, -RW and +R - none of these worked in my DVD drive. I can however play a DVD or CD and burn a CD using this DVD drive.
  • Skrin Dec 14, 2008
    I have a friend that is running a Dell, with DVD8631, and he's having the same problem. However, on my computer, I'm running a Sony DVD+-RW DL DRU810. I'm having the same problem with that also. The only thing that I find that works to solve the problem is to totally format the hard drive that contains the OS, and reinstall windows. I do know that there are certain programs that will cause this issue, and I have run into a couple of DVD's that will also make the drive act like this. Hope this helps someone.
  • demilo5524 Jan 03, 2009
    I have very similar problem with Philips DVD8631. It sporadically recognizes a blank DVD, while not recognizing about 5 to the one that is recognizes. There does not appear to be any reason. I just went thru 25 DVD+R and only 9 were recognized by Philips. The rest were invisible.
    Please advise if you find a solution!
  • darrenq1 Jan 25, 2009
    hi guys same prob here i have aphilips dvd+rw d28 which will burn cds no problem but has stoped reading dvds when i look at my computer with the drive empty it shows as a dvd/cd-rw drive ,however when i insert a dvd it changes the drive to a cd drive .i have phoned philips about this and installed all the new firmware with no result ,philips answer was to remove the drive and try it in another pc ,like so easy done, easy for the tech guys to say ova the phone .the device properties say its working properly but its clearly not , it did work fine ages ago but when u need it its just not playing ball ,any help would be great .
  • 1,003 Answers
Okay guys here's your solution use memorex dvd-r disc in these drives these are the most compatable disc out there.
Posted on Jan 15, 2008
2 Suggested Answers
  • 107 Answers
SOURCE: DVD-R/RW playing/burning only CD's
Try updating the firmware of the drive: (link not verified)
Posted on Jan 03, 2009
Ok i asked before if my drive will burn both dvd and cd. the answer was yes. but when i installed the drive and ran my dvd creator program. it said this drive is dvd read only.
Hi mikey7420 ,
The drive name itself is the clue to know whether it can burn dvds or not.
  • In your case it's a CD-RW (read and write or rewritable) and DVD-ROM (Read only memory and not read and write or rewritable as in the case of CD)
  • Perhaps the one who told you did not understand your question properly , and understood it , in the sense that it can read CDs as well as DVDs , as far as Dvd-ROM drives are concerned many shopkeepers who are especially new working in the shop just make a guess and answer our question which could lead to this misunderstanding or incorrect information being passed on.
  • So the next time you buy a DVD drive which should have a read and write functionality as well , then look up for a CD_RW,DVD-RW drive.
  • Also remember that DVD-RW drive can by default read and write CDs as well , but it's not true for CD drives..
  • So usually a DVD-RW drive can read and write Cds as well as DVDs but a CD-RW drive can either read or read and write a DVD depending on whether it's a DVD-ROM or DVD-RW.
Hope this helps.
May 11, 2011 | Philips CDD 5101 (CDD5101/33)...
Reads cds and dvds, but won't burn to them
Your drive can only burn CDs, not DVDs. To burn CDs you need to purchase a blank CD-R or CD-RW at a local computer store. You can burn a CD-R only once but a CD-RW can erased and written upon many time.
Try Nero software for burning.
Sep 19, 2009 | HP (377402-B21) CD-RW/DVD-ROM Combo Drive
HP dvd740b does not detect blank CDs and DVDs
i think you,ve hit the nail-on-the-head.
The laser has to power up highrer to write a DVD, or ocassionally have a dual laser. 1 for read/write CD. And 1 For Read/Write DVD.
Certain cd roms, only use CD- media. it,s probably worth checking which media is supported by the drive.
Also check the drives aren,t conflicting, on the same ide channel, sometimes swapping channels, ide primary/secondary can help, or swiitching Master/Slave/cable select jumpers on the drives Themselves.
Mike @ Compurepair.
Sep 04, 2009 | HP dvd740i DVD±RW Dual Layer Burner
My Philips DVD R/RW Drivde DVD8631/96(manufactured 2005)has died
Honestly, head over to a local computer shop and grab yourself a new OEM DVD RW. It should cost you somewhere in the range of $30. Don't go somewhere like BestBuy, as you will get charged obscene prices.
Make sure it has the right connectors, as many DVD drives are SATA these days. If you're not sure which you have, just bring it with you, and the staff should help you select the correct type.
Aug 04, 2009 | Dell Computers & Internet
My philips dvdr520h dvd player does not recognise the DVD+R or +RW blank disc's
because there is no way to use that, if you look at the manual that dvd only rec DVD-R
Jun 04, 2009 | Philips DVDR520H DVD Player/HDD
Philips DVD+RW SDVD8820 does not recognise burned CD or DVDs
it could be upper and lower filters in registry and system files, use a removal tool called filtercheck 4.6 in (goto the forums and search for filtercheck)
after you downoad, run it, click yes to all filters found to remove. close program.
reinstall your preferred burning app (1 prog installed at a time and test burn)
this is to replace the filter entry that was corrupt
Nov 09, 2008 | Computers & Internet
Assuming you have a dvd burner, do you have dvd decoder software or dvd burning software installed? Does it read burned dvds? Are you sure it's a dvd burner? If so, make sure the blank dvds you are using are the proper format ie; dvd+/-rw, etc. Good luck
Aug 19, 2007 | Acer Aspire 3624WXCi Notebook
Philips (DN4S2S05F/17) (5 Pack) (DN4S2S05F17) DVD-RW Storage Media Logo
1,224 people viewed this question
Top Philips Electronics - Others Experts
Bill Boyd
Tom Chichester
Are you a Philips Electronics - Other Expert? Answer questions, earn points and help others
