Question about Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HLP5063 the blue and green seem misaligned
On my samsung HLP5063 the blue and green seem misaligned or smeared on the screen. Its like a shadow that follows the picture. No loud noise is present. The picture sometimes goes black and white and is very clear. The problem seems to come and go every 5 to 7 seconds.
  • 106 Answers
You have what they call guns in the back of the tv blue/green and red and sounds like they have came out of adjustment. as far as the picture being black and white you should get a tv technician to check it
Posted on Aug 04, 2009
SOURCE:
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
Akai PT5598HDI Rear Screen Projection TV With Blue Shadowing
If the ghosting is like a 3D effect its your convergence ICs , but if its like a blue Halo around objects that usually means your CRT coolant has congealed and will need replacement. The blue is the first tube to congeal for some reason, followed by green. Red seems to be not quite as prone to this. It is a normal occurrence n sets about 4 years old to need the coolant changed.
Jan 25, 2008 | Televison & Video
My 47 in. Samsung flat screen hd tv has a picture but its a little dark then goes in and out of blue to green to red. It gets a good picture though. And the channel numbers blend together when I flip the...
Hello, I'm sorry to yell you that the lcd display (screen) is bad. Usually one side looks close to normal, and the other is dark and the picture drags and looks smeared. The cost to replace the lcd display is more than you can buy another set for, sorry. thanks, Terry
Oct 13, 2012 | Televison & Video
My screen has little dots appearing sometimes red sometimes blues behind the picture i just replaced the lamp bulb as i thought it would cure the problem
the projection tube needs to be adjust for color alignment, each tube (red, green, blue) must be aligned so you there would be no color smear appear on screen. if it is aligned try to set up the color balance, hue etc.
Feb 06, 2011 | Samsung Televison & Video
This tv have convergence problems,it dead.Red,green,blue misaligns colors,have colors shadows,3d colors pic like.All these problems are the convergence board have 2 STK convergence ICS some or all it resistors are dead.These parts must change to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 07, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My tv looks like it has double screen....for example a picture of a tree....right next to it would be another tree....double vision...
This is not a LCD tv,It a DLP tv.This tv have a problems known as Convergence problems.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the convergence board must be change to fixes 3D pictures,shadows colors pictures and Green,Blue,Red colors misaligns,don't matches up to form a good picture.The shop will u $300-350 for parts and labors.
May 24, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
The picture seems to be sliding down the screen of my Samsung HCN553W, I can still watch it except for the top 4-5 inches in the top left corner, it's black. Does anybody have any idea what it could be?
Ur tv it beginning to create and will develope a simtom call "Convergence alignment"These problems will delope in to the picture will have shades of colors like red or blue shadows,the picture bows in coners and colors will misaligns,the picture look like u watching a 3D movies,and the tv sometimes,just die and making chirpings sound.This problems very common in DLP tvs,it will develope just sonner or later that all.The covergence problems,the only way to fix are to take the tv aparts take out the Pc board call The Convergence board.Change the 2 STK convergence ICS,and some or all it supporting resitors and pico fuses.
May 06, 2010 | Samsung HCN553W 55" Rear Projection...
I have a HCN4727w samsung. Red/green shadowing. Bowed image
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 17, 2010 | Samsung HCN4226W 42" Rear Projection...
Toshiba 56HM195 56 in HD DLP Loud Buzzing and color distortion
If the sound, sounds more like a Hum with some vibration chances are the Cooling fan located behind the lamp is going bad, about $20 to repair, if its a high pitch hum most likely the Color Wheel and if thats the case about $30.
Good luck, my fan just went bad now seeing green dots everywhere, so debating on just junking it out or fixing it, with winter coming on might just breakdown and buy LCD and say the heck with DLP from now on.
Good luck to you..
Jan 27, 2008 | Toshiba 56HM195 56" Projection HDTV
Hitachi 50UX57B 50 inch Rear Projection smearing...
try this
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Sep 18, 2007 | Hitachi 50UX57B 50" Rear Projection...
Samsung HL-P5063W 50" Rear Projection HDTV Logo
162 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
