l
linda whelan Posted on Dec 13, 2018
People sending faxes say machine is busy - Office Equipment & Supplies
5 Related Answers
Anonymous
  • 432 Answers
  • Posted on Jun 25, 2007
SOURCE: Comm. Error
Try this website: http://www.instruccionesweb.com/u2/pdf/fax/Canon-L120-en.pdf
Anonymous
  • 159 Answers
  • Posted on Feb 12, 2008
SOURCE: We can't send or received faxes
Just a suggestion. This effect can happen if you have plugged the line cord into the tel jack instead of line jack.
Anonymous
  • 1463 Answers
  • Posted on May 12, 2008
SOURCE: We cannot receive or send faxes
hello dmhertz
anything here that may help Canon .
riz.
Anonymous
  • 215 Answers
  • Posted on Jul 10, 2009
SOURCE: Brother 4100 - can't send fax's - get busy notice
unplug machine, press and hold the "stop/clear" key and while holding key down, plug machine back in and continue to hold the button for 5 seconds. that should take care of problem.
hth,
razors
Anonymous
  • 236 Answers
  • Posted on Apr 04, 2011
SOURCE: My Brother MFC7340 Fax Machine
The busy signal that you hear when trying to send is likely from a receiver-off-hook tone.
The busy signal that someone gets when trying to fax you is due to a receiver being off-hook.
Suggest you check the following...
1. that the handset of the external telephone on the fax line is properly placed in its cradle.
2. if "hook" has been used/pressed on the fax machine, that it has been properly cancelled.
3. if there is an answering machine on the same fax line, that it is not off-hook / answering.
Why wont long distance faxes go through?
There could be several reasons why your fax machine is unable to send long-distance faxes. Here are a few possible causes to consider:
  1. Phone line issues: Long-distance faxes may require a stronger and more stable phone connection than local faxes. If there is interference or noise on the line, the fax machine may have difficulty communicating with the recipient's fax machine. You could try calling your phone company to check the line quality.
  2. Fax settings: Check that your fax settings are correct, including the country code and area code. It's also possible that the recipient's fax machine has changed settings or is experiencing technical issues.
  3. Busy phone lines: Long-distance fax transmissions may be affected by busy phone lines or heavy network traffic. You could try sending the fax at a different time, such as during off-peak hours.
  4. Fax machine issues: Your fax machine may have a hardware or software issue that is preventing it from sending long-distance faxes. You could try resetting the machine to its default settings or contacting the manufacturer for assistance.
It's also worth noting that some businesses and organizations have implemented measures to prevent unsolicited faxes, such as blocking faxes from unknown or unapproved numbers. If you're still having trouble after checking the above factors, you could try contacting the recipient to ensure they are able to receive faxes from your number.
The fax machine will not faxes, it prints out as busy.
make sure the cable is in the LINE socket not the TEL socket as this will stop connection..
Receiving faxes
Certainly not your fax machine problem.
The client needs to verify your fax number.
2answers
Samsung SF 3200
The person you are sending to has a busy phone line.
Call your cell phone from the fax machine to test.
1helpful
Not connecting to fax out
Do you have a DSL or other digital phone line?
Receive faxes but can't send
Instead of trying to send a fax try to call the number from a different phone. To see if the receiver is busy all the time..
Can't send out fax
the number you called does not answer or busy-you may have reached a number not connected to fax or it is connected and not activated in receiving mode-check the number and call again.
if you have a message "out of memory"there is no enough memory available to send your fax.press stop/exit print the faxes stored in the memory to delete them then try again.
Can't receive faxes
Something is causing the fax machine to "trip" to busy. There is some type of short occuring either in the fax machine or the physical phone line itself. Unplug the fax, plug in a regular single line telephone. Call the fax number from another telephone. If the phone rings and you can talk to the other party, the problem is in your fax machine. If the call still is busy, the problem is in your wiring, either in your office or the phone company network.
k24674
ADMIN Andrew
ADMIN Andrew
