Coffee Makers & Espresso Machines Logo
Suzelle Haas Posted on Dec 13, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Miele coffee maker only dispenses dirty water -- the coffee grinder grinds, but actual coffee never comes out. Help!!
mpservices
Level 2:
Wolfpack:
An expert that has 5 followers.
  • Miele Expert 191 Answers
  • Posted on Oct 12, 2019
mpservices
Miele Expert
Level 2:
Wolfpack:
Answers
191
Questions
0
Helped
245777
Points
342
I am guessing the waste basket is empty as well. you may hear the grinder turning but it sounds like no beans are being fed or something is stopping them from falling in the chute - another possibility is the coffee chute (after the grinder) is plugged up as well - sometimes using an oily bean ( dark and shiny) will do this
you can sometimes clear it from the ground coffee chute above the brew unit - but take care not to damage or cause injury to yourself or the unit
5 Related Answers
A
Anonymous
  • Posted on Jul 17, 2007
SOURCE: Grinder spins but won't grind coffee
You have fill a water in your coffee grin
Anonymous
  • 8 Answers
  • Posted on Dec 09, 2007
SOURCE: Coffee beans will not grind
If the grinder is blocked try changing the grinder setting up to the coarsest setting (I think it is numbered 16 on this model) and then vacuum or fill with beans and push them through. Be sure that any damp coffee has gone as you don't want the grinder blades to be left wet.
Never freeze or refrigerate your coffee beans as the condensation from doing this can also block your grinder. Also never use coffees that have been flavoured during the roasting process as they are often too sticky or oily and will block your grinder. These coffees should be ground using a grinder that can be easily pulled apart for cleaning...which is not the case in the Saeco automatic machines.
After you have finished clearing your grinder you will want to turn it back down to a finer setting ( a setting of 6 or 7 works well on this model) however you should only turn the grinder setting finer while the machine is actaully grinding. Otherwise you may find the coffee beans jam between the blades.
If you are unable to clear the blockage it might need to go to a technician.
Anonymous
  • 515 Answers
  • Posted on Jul 18, 2008
SOURCE: Saeco coffee machine
I think your grinder engine has broken and have to be replaced.
Anonymous
  • 1089 Answers
  • Posted on Jan 25, 2010
SOURCE: the coffee grinder on my Magic Comfort Plus is not
Hi Sounds like you have a blockage in you grind passage. Try removing the brew group. Then inside on the roof of the machine where the brew unit was setting there is a drop chute where the coffee is dropped into the brew unit. From the left side of the drop chute pull down and back, and it will drop coffee. This will clear an opening that relieves pressure on the passage. There is a passage inside the drop chute area that goes to the grinder. Vacuum it out. It will be on the right side of the drop chute. Once that is cleared go to the bean hopper. There is a lever under the bean hopper. Push the lever back to the largest number. You can push the lever to a larger number any time, but it has to be grinding to pull to a smaller number. Now replace everything and make your coffee. Once you have made your coffee you can pull back to a number that was higher than the one you had it on, but only when the grinder is running.
Anonymous
  • 22 Answers
  • Posted on Jan 31, 2010
SOURCE: A Krups KM7005 coffee maker/grinder doesn't heat or drip water .
Mine had the same problem ... all the lights are on, grinding works fine, but no heat on the plate, and no dripping of water.
After a weekend on the workbench, I mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. To date, I have helped 13 people on this site fix this exact problem.
I'll be happy to advise you to fix this, or fix it for you. Write me at [email protected].
Miele CVA 4085, the grinder is not grinding the beans. It makes the noise but basically water just comes out with very little coffee.
Here are some specific steps you can take to try to repair the grinder issue with your Miele CVA 4085 coffee machine:
  1. Clean the grinder: Remove any coffee grounds that may have accumulated in the grinder mechanism, and clean it thoroughly with a brush or cloth.
  2. Check the grind burrs: Inspect the grind burrs for any signs of wear or damage, such as chips or cracks. If they are worn, they may need to be replaced.
  3. Adjust the grind setting: Make sure that the grind setting is adjusted correctly for your type of coffee beans. If it is set too fine, the grinder may struggle to process the beans.
  4. Check the grinder motor: Make sure that the grinder motor is functioning properly and that it is not overheating. If it is making a strange noise or if it seems to be struggling to turn, it may need to be repaired or replaced.
  5. Reassemble the grinder: Make sure that the grinder mechanism is properly assembled and that all components are securely fastened.
If these steps do not resolve the issue, it may be necessary to have a professional service the machine.
Regenerate response
Miele KM-6350 coffee maker says 'drink cancelled' fill coffee beans.
Question edited for clarity.
Question moved from Misc.
These machines are problematical and are on this site all the time with problems. The videos may help.
Miele coffee machine CVA4080 coffee grinder works but not well... coffee is coming out the waste in chunks not a fine powder.
Question moved to Miele.
This particular machine ends up on Fixya a couple of times every week!
Some Miele machines have a lever to adjust the grind coarseness. Page 27 of the manual below. I would also give it a good clean beforehand to check there is nothing in there that shouldn't be.
https://www.google.com/search?q=miele+coffee+machine+cva4080+adjust+grinder+size
Parts
https://www.google.com/search?q=miele+coffee+machine+cva4080+grinder+replacement+parts
Miele CVA 4080 Manuals - ManualsLib
https://www.manualslib.com > ... > Coffee Maker
Miele CVA 4080 Operating And Installation Manual (84 pages). Built-in coffee machine. Brand: Miele ' Category: Coffee Maker ' Size: 0.94 MB. Table of Contents.
Miele CVA 4080 user manual (English - 84 pages) - Manuals.ca
https://www.manuals.ca > Coffee makers > Miele
View the manual for the Miele CVA 4080 here, for free. This manual comes under the category Coffee makers and has been rated by 3 people with an average of ... .
Miele CVA4066. When you press the coffee button, there is a pause i hear a relay click near the grinder, but it does actually move or start grinding anything, then hot water starts to come out.
Its a grinder problem but to fix this you need detailed technical knowledge and experience. It can be one of three things; 1. The Grinder has an inline protective sensor that sits on outside of grinder and can go open circuit. Test by bypassing but do not run unit without this. 2. The motor brushes can be worn out. Unfortunately Miele does not sell new brushes and so you have to replace grinder unless you can fabricate your own. The symptoms of this are a gradual change in grinder speed. 3. The grinder is burn out in which case you must replace unit.
So if this was a sudden fault then its 1 or 3. Regards
1helpful
What would cause the machine to grind the beans but not produce any coffee despite the water tank being full?
Your grinder setting might be too fine. Only adjust while the grinder is grinding -- set to a coarser grind. Have you tried the preground coffee dispenser? Again, use coarser ground coffee in case the sieve is getting clogged.
The grinder is not working
Likely causes are grinder has burnt out or temperature cut-out for Grinder has blown. Either can be replaced as a spare from Miele.
The grinder is not working. Only water is coming out.
Basically coffee is not being ground. Likely causes are grinder is faulty or temperature cut-out for Grinder has blown. Either can be replaced as a spare from Miele. Note: A possible cause for Grinder not working is that the carbon brushes are worn away preventing electrical contact. Unfortunately Miele does not sell brushes as a spare part.
I owe the miele CVA4075 BUT my whole bean grinder is not grinding the bean and only water gets dispensed, anyone have a solution?
Make sure the hopper is working correctly to see if there are any blockages, then check under the hopper to the opening where the beans go to the grinder. My guess is that there are a few beans and chipped portions of beans which are clogged under there.
Hi. I have a miele cva4060. The grinder is working but it does not seem to be getting any beans through it and I am only getting water dispensed instead of a coffee shot! It was working fine a few days...
Hi
If you hear its 'grinding' then that's good - problem is where is the ground coffee going or supposed to go??
Check there is no build up of damp/dried coffee grinds in the pathway between grinder and brew unit - this can happen if the machine is not properly cleaned say every 3 mths or more often depending on usage - coffee 'dust' can build up.
Also suggest remove all beans from grinder, vacumn last ones out. clean all around grinder opening. Add a dozen or so beans to the grinder, turn on and try again. If the beans disappear, its grinding properly. If they don't end up in the brew unit, then the hold up is as I said in that pathway - grinder to brew unit. If you cant see an obvious blockage/build up, suggest you have a tech look at it.
Cheers
Mike
Grinding
Do you "hear the coffegrinder trying to grind", and after that only hot water comes out?
Does it grind and just release the coffe in to the dregdraw dry?
"standard first sollution for me when a grinder is malfunctioning is to. set the grinder to more coarse and see if it starts to work again."
Top Miele Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Aron
David Spradling
David Spradling
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
