Question about HP (5064-6604) ( 5064-6604 ) 300-Watt Power Supply
Power Supply I purchased several electronic components while overseas which are 220-240V input,a Sony TV, Sony 5.1 receiver and a Sony CD/DVD player. Can the power boards be swapped out to accomodate 110V input?
  • 121 Answers
Re: Power Supply
Possibly, but I think it would be easier to go to radio shack or some similar shop and buy a 110->220V converter. Check the load it can handle; you might need more than one.
Also check the powersupplies on your appliances to see if they have a swithchable powersupply. Manby PCs have these, because it's cheaper to make one kind of switchable supply than two kinds of non-switchables.
There might be a sticker over the switch to prevent "stupid users" to try the switch to se what it does. If there is one, it should be marked 110/220.
Posted on Nov 26, 2007
  • HP Master
  • 5,568 Answers
Re: Power Supply
On your Sony TV; you didn't specify in which country you purchased the set.  There is a good chance that it will not be usable in the US unless it was built to accommodate both the PAL and NTSC signals which are not compatible. If purchased some time ago in France or several other countries using SECAM, this system isn't compatible with either of the above; hey, we are FRENCH we don't need no stinking compatibility! If it is digitally compatible it may work with only the step-up transformer cramsvik wrote of and I am not up to speed on any incompatibilities between the US and European standards.
Posted on Apr 27, 2009
0 characters
3 Points
I have the dynex 400 watt atx power supply,connector do I use my sata connector.
They try to make them "idiot proof." Only the correct one should fit in the power receptacle on the dvd/cd player.
Try the different ones and don't force anything...
Mar 09, 2014 | Dynex 400-Watt ATX CPU Power Supply
Receiving no signal with converter box
Where is the "no signal" coming from, the converter box or tv? If tv then unplug the dvd player and plug the plugs into the converter so the wires go from the converter into the rf modulator. set the tv up to watch dvds and try your channel scan gain. If it works then post again and we'll figure out the best way to connect the converter and dvd to the tv.
Jul 30, 2009 | Apex Digital (AL-A300ATX) 300-Watt Power...
No power
An AT power supply must have current draw to turn on. Remove every component not needed for boot ( Floppy, Hard, CD DVD Fan. Leave on Motherboard and CPU and Fan. With header connections connected ( HDD led, PWR on, PWR Led and speaker ) push the on switch and make sure the back of supply doesn't have a switch. Does anything happen? Write me back if you want and we'll try to get some juice out of the supply.
Jun 28, 2009 | System Power Supplies
Dell Dimension power problem
There are several different solutions for this as posted at this Forum.
1) A lot of people have just removed the Jumper for the CMOS and turned the Power back on and back off and replaced the jumper and/or removed the battery.
2) Several people have reseated the Memory and after booting back up it worked.
3) A few had to replace the Mother Board and CPU but in this instance they had to also replace the Case because the Dell case wasn't really fit for the heat of from the CPU.
4) I had the exact same problem and luckily replacing the Power Supply fixed this for me. I had to cut out the back of the Dell case for the toggle on/off switch but when I tested the old Power Supply it was only getting 5amps and this was causing the Amber/Orange/Yellow light to constantly flash.
I hope this helps!
Jan 20, 2009 | Dell Dimension 8400 power supply ** FREE...
Have a yellow amber light blinking
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Dec 25, 2008 | Dell Dimension 8400 power supply ** FREE...
Schematic diagram for ATX-250-12E
I repair power supplies and various electroics, most cases it will be compacitors, or diodes which have caused it to fail!!
Jul 29, 2008 | Bestec (ATX-250-12E) 250-Watt Power Supply
HP (5064-6604) ( 5064-6604 ) 300-Watt Power Supply Logo
111 people viewed this question
Top HP System Power Supplies Experts
Brian Sullivan
Brian Sullivan
Sudeep Chatterjee
Sudeep Chatterjee
Are you a HP System Power Supply Expert? Answer questions, earn points and help others
