Question about Tascam Audio Players & Recorders
I have a tascam dr -1 and system error 50 is on screen. what do i do please?
SOURCE:
SOURCE: tascam dp-01fx system 50 error
what the above guest said is exactly what you need to do. Make sure of course there is nothing on your FAT(previously exported songs/masters) because they will be erased. just go to menu->disk->fat reform, then press enter
Posted on Dec 18, 2007
SOURCE: Tascam dr-1 recording problem
There is a "PB Control" button. I had the same problem. You've inadvertently told it to change the speed or something on playback. Make sure that none of the indicators at the top of the screen are active (i.e., white letters on black background). Press the PB Control button to toggle it on/off. Also, any files transferred to a computer will not be affected.
Posted on Feb 08, 2009
SOURCE: Tascam DP-02 error 50:0
this happened to my dr-1 what i did is took out the SD card, used a card reader to put all the songs from the music folder onto my laptop, then erased the songs from the card, reinserted it into the Dr-1 and no more error.
hope it helps. tascam doesn't come with a card reader, they use a usb but i've found that a card reader is faster and easier to manage. you can get one anywhere they sell electronics for about $15. cheers
Posted on Jul 25, 2009
SOURCE: recording stops and recorder freezes with tascam 2488mk2
this has happened to me too- with different system error codes also not referred to at all in manual !!! i don't know of solution- and have lost the current recording session by having to just turn the device off and hope for the best... i plan on contacting tascam after this project is complete since my unit is still under warranty - GOOD LUCK out there
Posted on Jan 15, 2011
  • 5603 Answers
SOURCE: i need instalation diagram for tascam DR-1 to
We don't have any graphic means of diagramming. You also don't say if this is for recording or playing or both. Assuming it is both, your best way would be to get two 1/8 stereo cables that split into two RCA plugs. Go from the headphone out of the DR1 to the CD inout jacks on the mixer. Then with the second cable go from teh CD out jacks of the mixer to the line in of the DR1.
Posted on Mar 31, 2011
Tascam dr-07 when I turn on the display reads system err 50
Kennedy, Do hard reset by hold down the track edit and up arrow keys simultaneously while powering up. It will re-initialize the disk and ask you if you're sure you want to. Ans. yes using the (yes/enter) key, and the unit will re-boot itself and return to the welcome screen as loaded from the factory.
PRESS THE HELPFUL BUTTON
https://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwji99_noujKAhXKJB4KHctTDsIQFggjMAE&url=https%3A%2F%2Fwww.educ.cam.ac.uk%2Fservices%2Favs%2Floanstock%2Fmanuals%2FUser-Manual-Tascam-DR-07.pdf&usg=AFQjCNEmPJ4OCw7_ULc8zPDMmrafuRMIQw&bvm=bv.113370389,d.dmo
Tascam DR 07mkII Owner Manual Page 116
Amazon com Customer Reviews Tascam DR07 Portable Digital Recorder
Feb 08, 2016 | Tascam Audio Players & Recorders
Tascam DR-05 Blank Screen
Always do the easy thing first, make sure your batteries are good and in right. You may not have the back light on. In your menu scroll down to "other", scroll over to the right. Scroll down to "system", scroll over to the right. Scroll down to "back light", over to the right then move up or down for how ever long you want the black light to stay on.
Jan 19, 2013 | Tascam DR-05 Portable Digital Recorder
My tascam dr 100 gives a 'writing failed' file error' message and stops recording
Try using a smaller memory card. This only happens to me when using a 4- or 8-gig card. 2-gig and below, No error.
Feb 24, 2012 | Tascam DR-1 MP3 Player
When I turn it on I get "System Err 50 please pwr off" how do I fix it.
Hi this is the only solution for your query jut do that
i) If these error occur, turn the DR-1 power OFF and restart the unit. If the error message continues to appear, contact a TEAC Repair Center
other than that no solution we have so far.
Apr 13, 2010 | Tascam DR-1 MP3 Player
DR-1 MAC FINDER does not see it!
I had a similar problem. What i did was to replace the tascam provided cable with another one (similar) from Iriver t30. works wonders. found out that the original cable couldnt plugged in properly to tascam although it did recharge the unit.
Hope that helps.
Jun 03, 2009 | Tascam DR-1 MP3 Player
My Tascam DR-1 digital recorder will not turn on
To initialise the Tascam DR-05:
Press and hold the + button and the Mark button while turning on.
Thanks
Feb 03, 2009 | Tascam DR-1 MP3 Player
Nov 05, 2008 | Tascam DR-1 MP3 Player
Tascam dp-01fx
I am having pretty much the same issue....
Let me know if you found a solution.
Jun 04, 2008 | Tascam DP01 All-In-One Recording Package...
Mar 16, 2008 | Audio Players & Recorders
137 people viewed this question
Top Tascam Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
