SOURCE: Remote Antenna
I suggest LMR-400 cable, but generally most any coax cable will do. As far as your connectors, I suggest visiting RadioShack or The Source for these, remove your existing antenna and bring it with you to determine what N-Connectors you will need.
SOURCE: acquiring signal
Even with the antenna looking like it is in good shape, it still may be the problem here. Physical damage may not be present, but there could be electrical damage (power surge) or corrosion on the antenna if it is in a moist environment. A quick trip to a local stereo shop can confirm this as new antenna can be plugged in to the unit to test. Also, the problem is more evident when the antenna is mounted inside the vehicle. For best reception, it is recommended that the antenna be mounted to the exterior of the vehicle and have a clear view of the sky. Make sure that there is plenty of metal underneath the antenna and you should be fine.
SOURCE: Replacing Antenna 2001 Yukon
Man...you have no idea what a job this is! Go to a car stereo shop and pay somebody to do it!
Good Luck
SOURCE: After a storm, TV registers
Hello
you haven't given the brand name and model numbe of TV here. yet I posts this solution assuming that it to be LCD tv. You says that the Tv works with converter and not works with digital box. Check the digital box for any malfunction. I can oly give you this much advice as your post does not tell exatly what the fault is. If you want anymore assistance from me, please be clear out the situation you faces now. OK.
