Instuctions I have a VCR and remote. I can play videos but cannot record tv channels. no channels show .Do i need to tune in? How?
  • Anonymous Feb 26, 2008
    vcr will not record from tuner or a/v jacks. vcr will work as tuner to tv.
  • 175 Answers
Ok tell me whats the setups of your cables ANTENNA from TV to VCR?
tell if the setup are same below..
antenna cable to RF input of VCR and
RF out of VCR to
TV RF input
peace!
Posted on Nov 26, 2007
I have a mitsubishi black dimond vcr id like to tune into a sharp tv how do i do this please
Ok, to hook it up to use as a Receiver, and TV, as a "Monitor". Using the antenna cable, plug this into the antenna IN socket on VCR. Now connect up, AV, using the Yellow, Video, Audio, is Red & White, on BOTH TV & Video. Now select an EXTERNAL INPUT on the TV. Now You Tune, and scan for "Channels" using the VCR. Find each channel, and save, now, you use the VCR remote to change channels, and the TV, is used as a "Display Monitor".
The Other way, is to just use the VCR as a "Recorder only, you plug the antenna, into the TV, now at rear of TV, you have a Video OUT, Yellow, and Stereo, Audio OUT, Red & White. Connect up the VCR to the TV using them. Now anything you View on TV, will be out put to the VCR, when you wish to record, simply press record, on Remote/VCR as desired. and it will record.
Apr 08, 2010 | Televison & Video
I want to set up my video recorder to my tv and have forgotten how to do it. I have connected the two by aeriel but cannot see what else to do.
Youe aerial should be in the rear of the VCR & the other cable (flylead) should come from the output connection of the VCR & into the TV. To easily find the VCR channel insert a film tape into the video & press play, now selecting the VCR channel on the TV (EG. channel number 0) now you will need to go into the manual tuning on the TV & search until it finds the playback film, once this happens, store this setting. An easier alternative would be to buy a scart connector & connect this from the VCR to the TV & then the video channel will show on the AV setting on the TV, this saves you any tuning problem.
Oct 14, 2009 | Daewoo Televison & Video
Connect vcr to jvc c2033us tv
You will need to put your aerial into the rear uhf socket of the VCR then take another connecting lead (flylead) from the out of the VCR & put this into the aerial socket of the TV. You will now need to select a channel on the TV (best to use channel zero) & tune the TV to the VCR signal. The best way to do this is to put in a recorded tape eg a film /press play/ then tune the TV until you pick up the playback of the film, then store this on the TV. This will give you your VCR channel. You will now need to tune the VCR to your broadcasted stations so that you can record.
Apr 01, 2009 | JVC Televison & Video
I want to tune a vcr to a playsonic tv. the vcr
I don't have the remote control with me, how can I do to put AV1, without remote? Its that possible?
Mar 14, 2009 | Televison & Video
I need playback channel for tv to be ch.4 -
Solution 1
How to set the DVD Recorder+VCR’s RF output channel
Turn off the DVD Recorder+VCR, then press and hold
CH (v/V) on the front panel for about five
seconds to change the RF output channel (CH 03 or
CH 04). “RF 03” or “RF 04” appears on the front panel display.
Solution 2
Cable Service With Cable Box
If a cable box is required in your cable system, follow the
instructions shown below. This hookup permits both TV and
DVD Recorder+VCR operation.
To view or record a CATV channel:
1 Tune the TV to the correct video input channel.
2 Set the DVD Recorder+VCR to the output channel of the
cable box using the CH (v / V) or the 0-9 keys on your DVD
Recorder+VCR (e.g., CH3).
3 Select the channel you wish to view on the cable box.
Please rate this a fixya
Jan 30, 2009 | GoVideo Go Video DVD/VCR Combo
Tuning channels in VCR mode to record
wich deice are you trying to record shows onto the vcr or dvd recorder? what is the brand and model of the unit?
Dec 19, 2008 | Televison & Video
Change TV channel on SAMSUNG DVD-VR350
Hello Giancarlo, You'll have to use the projectors remote for T.V. tuning. I don't think the samsung DVD remote will operate your projector or your T.V. channels, will it? If it does, You just have to switch the input button on the remote to change between T.V. and Video. I hope that helps.
Jun 02, 2017 | Samsung DVD-VR320 DVD Recorder/VCR
Problems tuning TV and SLV-900
the video recorder has it's own tuner you do not actually record from the tv... think of the vcr as like a tv but without a screen... connect to your tv via a scart lead and while you are on the vcr's 'channel' (so you could see a tape playing on your tv) and access the menu on you vcr (not the tv's menu) choos auto tune if the vcr supports it or manual tune if it has no auto tune and tune in the required channels on your vcr... it is simply then a matter of selecting on your vcr which channel you wish to record
Oct 13, 2008 | Sony SLV-D900 DVD Player / VCR Combo
Panasonic NV SJ205 changing RF settings
Your VCR has input to record video-audio signal. Here is 2 options to record program in vcr.
1= You need to hook up video-audio cable at Monitor Out in TV and video-audio in at VCR. select Line-1 or Line-2 (where you hook up cable) in vcr and insert cassette with Record Tab intact, VCR is ready to record TV program. select desired channel on tv and hit record button of vcr, recording will start.
2= Plug RF antenna / cable wire in RF In of vcr and tune desired channel in vcr (get help of vcr's user manual for that) and push record button to start record directly in vcr.
Have further query, let me know please.
bye.
Sep 09, 2008 | Panasonic NV-SJ205 VHS VCR
Akai VSG285 video - I can't tune any TV stations thru to the VCR?
This sounds like a hookup or programming problem.
The typical hookup is cable/satellite box output to VCR antenna/RF input, then VCR antenna/RF output to television input. Since you are able to watch pre-recorded tapes, the latter is already correct. There are other ways to connect, using the audio/video outputs of VCR to audio/video inputs of the TV. Older or low end TV sets may not have these connections.
If by chance you are using an outdoor antenna (not cable or satellite) then the antenna connects to VCR antenna/RF input and VCR output as above. You will also need to program the VCR into the stations- most late VCRs will scan for active channels, and program themselves to those channels.
I'm not sure of the capabilities of newer cable & sat boxes, but generally, you had to tune that box to the channel you wanted to record. The VCR is set to channel 3 or 4 depending on the output of the cable box.
Lastly, most VCRs of the last 10+ years require the remote to setup advanced functions, such as timed record, date & channel setup functions. The buttons on the VCR itself only do very basic functions, Stop/Play/Rewind/F-forward/Eject etc.
If you don't have the orig. remote, some universal remotes may be able to do advanced programming functions.
Apr 09, 2008 | Televison & Video
Open Questions:
Televison & Video Logo
121 people viewed this question
Top Televison & Video Experts
