Question about Kenmore 24 in. 17362 / 17364 / 17369 Built-in Dishwasher
AEG Dishwasher My dishwasher is just 2 years old and I did a Finish cleaning cycle on Friday. This normally works very well, but everything is covered with a thick opaque film of dust, which is difficult to wash off.
  • 76 Answers
Are you using these all in one tablets? if so I would still advise to add salt as without this you will get limescale build up espesially if you are in a hard water area, hopefully this will solve your problem.
Posted on Nov 27, 2007
My dishwasher has water in it and want spin out.it washies and heat up to dry but will not drain the water out.what should I do go out and buy another one?
Posted on Nov 06, 2008
I have a AEG 50870 Favorit dishwasher, it is not letting water in, although when I manually put water in, it drains properly
Hello.
Had same problem on my AEG F55204 dishwasher.
Problem solved very easily. cleaned pressure chamber only.
see attached pictures
clened aeg pressure chamber-gpfsjtvpk02j51hgnqm10fvj-4-2.pngHope it will help to you as well.
FYG no need to dismantle everything. just take off fwrd cover to check chamber and then use some small wire to clean it from inside.
Oct 09, 2017 | AEG Dishwashers
Dishes not coming out clean
Hello
There are some things you can try, however, if your Maytag dishwasher is not getting your dishes as clean as you would like. Maytag recommends several processes for fixing this issue with your dishwasher.
Do not run your Maytag dishwasher while hot water is being used in other parts of your home, such as washing clothes or showering. Hot water is needed for your Maytag dishwasher to properly clean dishes.
Run water in the sink in your kitchen until it gets very hot. Then, turn on your Maytag dishwasher. This will ensure that the water cleaning your dishes is the hottest possible temperature.
Clean your Maytag dishwasher to improve the cleaning results for dishes. Run your dishwasher on a short wash cycle and wait for it to fill up with water. Stop the cycle and add about 1/3 of a cup of rust remover to the dishwasher and finish the cycle. Run your Maytag dishwasher through one normal cycle with regular detergent to finish the cleaning process.
Check your detergent. Old detergent or those that have been exposed to moisture can be clumpy. This detergent will not clean your dishes as well when loaded into your Maytag dishwasher. Purchase fresh detergent.
Use extra detergent when washing dishes that have a lot of built-up grease or food particles. The extra amount of detergent is needed to get your dishes clean. Choose a long cleaning cycle to clean these dishes.
Fill your Maytag dishwasher properly. Dishes should not be stacked on top of each other or excessively crammed into your dishwasher. This will keep the dishwasher from adequately cleaning all areas of your dishes and from rinsing them thoroughly.
Sep 13, 2011 | Maytag Dishwashers
My Bosch dishwasher is only 2 yrs old and for the following two nights does not want to pump out the water. If I drain it, it sometimes starts the cycle and sometimes not?
If no warning lights show up, then it is a matter of finding if the outlet is blocked somewhere. I am assuming the fact you can drain it manually means the pump is ok. Perhaps some sensor which is covered in muck.
I would start by cleaning the filters at the base and then running the unit with a dishwasher cleaning kit (without dishes in it). Finish cleaning kit is quite good and the instructions are on the pack.
By the way these units normally have a 2 to 3 year warranty on some parts. I am assuming you have the proof of purchase so that you can call the Bosch support guys.
May 07, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
We dont know how 2 turn it on just moved house n no instructions aeg oko favorit dishwasher
Looks like what you need is available at
http://www.serviceforce.co.uk/pdfs/U20206.pdf
Good luck with the new house. Hope the dishwasher works well for you.
Try to run it with dishwasher cleaning kit (no utensils) to make sure everything is clean - that way you will get more life out of it. The cleaning kit (usually Finish) is sold in the supermarket in the detergent section.
Jan 31, 2010 | AEG 18 in. Favorit 54750Vi Slim-Line...
Dishwasher won't cycle
Sounds like you need a new timer. Costs about $50 - $60. I had the same problem. The knob now turns. Hope this helps.
May 18, 2009 | GE Nautilus 24" Built-in Dishwasher
Kenmore elete dishwasher flashing light clean
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Dec 06, 2008 | Kenmore 24 in. 15173 Stainless Steel...
Having problems with AEG dishwasher-tablet not dissolving..
open the door when in cycle and check both spray arms are rotating. you will get a bit of water out but not a lot. if arms not rotating, then this is caused usually by rubbish in the spray arm jets so clean them. also check water is being heated
Aug 05, 2008 | AEG 18 in. Favorit 54750Vi Slim-Line...
Kenmore 24 in. 17362 / 17364 / 17369 Built-in Dishwasher Logo
111 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
