Question about HP LaserJet 1020 Printer
Blank space in between the page
When I'm trying to give printout, i get blank space in between the page layout from top to bottom of my print.
  • Lakshman SPa Dec 20, 2007
    still my problem not solved, what to do even after this all done?
  • elmir Dec 26, 2007
    When I try to print a document I get a blank space in the middle of the page.
    If I reposition the cartridge it may (or it may not) improve for a page or to bun then the same happens again.
    President:
  • 4,402 Answers
Http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00602236&cc=us&lc=en&dlc=en&product=439320&dlc=en&lang=en
Posted on Dec 13, 2007
  • Cary Farah
    Cary Farah Dec 20, 2007
    what application are you using to print MS Word?
    if so check:
    1. While in Word, click
      Tools
      , then
      Options
    2. Select the
      Print
      tab.
    3. Uncheck
      Allow A4/Letter paper resizing
    4. Click
      OK
    5. Re-send the print job.
    here is a list of all the problems with that printer
    http://h10025.www1.hp.com/ewfrf/wc/docum...
Lexmark x2650 printing vertical on pages not horizontal why
when you click print, select preferences and then paper layout, choose portrait or landscape there to change the print layout.
Dec 29, 2012 | Lexmark X2650 All-In-One InkJet Printer
I am trying to print a booklet 2 pages per sheet double sided. Printing is OK but spacing is no good for the binding when the pages are cut in two. What instructions should I give the printer to allow...
Hi
By spacing, I assume you mean the margins at the centre.
The default margin settings are not the same for the right and left hand side of the page, so the printing on the reverse side is offset from the printing on the first side.
The right margin is always wider to allow for punch holes in file paper.
It is not the printer settings you need to adjust, it is the page layout of your word processing software.
Adjust the margin settings manually. In MS Office 2007:
Page Layout > Margins > Mirrored Margins.
Hope this helps.
Aug 24, 2011 | Canon PIXMA MP610 InkJet Printer
I loaded MS Office 2003 on a new laptop running Windows 7, only to find that Word opens as a blank page with no toolbars, rulers etc - only the writing area. Excell works ok
The Word 2003 Window When Word is first started, a new blank page titled Document1 is opened automatically. This is a fresh page where you can begin typing a new document.
  • At the top of the window is a row of menus, including File, Edit and View.
  • Below that row of menus is a row of buttons for various tools (collectively called the "toolbars") to use in creating and editing your document.
Layouts in Word 2003
Normal - Normal is the default Word 2003 view. It shows just the text that you are working on, without margins or header and footer information. It doesn't differentiate between different pages of text.
Web Layout - The Web Layout displays the document as if it were a web page
Print Layout - The Print Layout shows the entire page you are working on, including margins, header and footer information. It shows the layout of the text on the page the way it would be displayed if printed.
Feb 05, 2010 | Microsoft Office 2003 Small Business...
Hp 4300 laserjet. All printouts have a blank space
Remove the toner and wipe the small window that's above where the drum unit sits inside. That window gets covered with toner and makes light prints and blank areas.
Nov 18, 2009 | Office Equipment & Supplies
Layout/Printing issues
FileMaker 5.5 is a long time ago for me, but I think I will try to answer your question (although it is likely you have a solution or no longer need one.) While in layout mode, while working on the layout, go to printer setup and choose the printer and page size you will be printing to. This will cause FileMaker to have a dashed line where the printer pages are on the layout. Anything that extends over these lines will require additional pages to print. Simply bring everything back in before these lines to limit to 1 page (including the blank space at the bottom of the page. There is a tab you will need to drag above the page break line to prevent a second page from printing. Additionally, if you cannot work it out, while printing from FileMaker if you choose the page range of 1 to 1, only 1 page will print, however, doing this prevents you from printing additional records without writing a script to do it. However, if you are able to redesign the layout to only print 1 page then you will notice there is an option on the print dialog box that indicates something to the effect of "Print current record" and "Print records currently being browsed" (Don't remember the exact wording in FileMaker 5.5); Choosing the records currently being browsed option will print all records in your current found set.
I hope I've done a good job answering your question. I am a FileMaker expert for version after 7 and have used Filemaker since version 4; if you have any additional questions I will do my best to answer them. If my answer was helpful for you I'd appreciate a 5 thumbs up rating, or a click on the yes this was helpful button. Thank you!
Apr 06, 2009 | FileMaker Server 5.5 (540100U) for Mac, PC
Designing a document in book form and printing in Word 2007
When you select Book fold for your page setup, Microsoft Word prints two pages on one side of the paper. When you fold the paper, it opens like a book. This option is intended for documents that have more than two pages.
1. Set up your document as a booklet.
When you create a booklet, it's best to start with a new, blank document so that you have better control over the placement of text, graphics, and other elements. You can add a book fold to an existing document, but you may have to reposition some elements once the book fold is in place.
A. Start a new, blank document.
B. On the File menu, click Page Setup, and then click the Margins tab.
C. In the Multiple pages list, select Book fold.
If your document is not set to landscape orientation, Microsoft Word sets it to landscape.
D. In the Inside and Outside boxes, type or select the amount of space you want for the inside and outside margins (margin: The blank space outside the printing area on a page.).
If you need even more space along the fold to accommodate binding, type or select the amount of space you want in the Gutter box.
E. In the Sheets per booklet list, select the number of pages you want to include in a single booklet.
If the number of pages in the document exceeds the number of pages you select for a booklet, Word prints the document as multiple booklets.
F. Select any other options you want in the Page Setup dialog box.
G. Add text, graphics, headers or footers (header and footer: A header, which can consist of text or graphics, appears at the top of every page in a section. A footer appears at the bottom of every page. Headers and footers often contain page numbers, chapter titles, dates, and author names.), and other elements to your document as usual.
2. On the File menu, click Print.
3. Set options for printing on both sides of the paper.
If you're using a duplex printer (one that automatically prints on both sides of the paper)
Click Properties, and then set the options you want. If you have a choice of setting the page orientation and duplex options, select landscape orientation, and flip the document on the short edge or short side.
If you aren't using a duplex printer
In the Print dialog box, select the Manual duplex check box. Word will print all of the pages that appear on one side of the paper, and then prompt you to turn the stack over and feed the pages again.
4. Select the page range you want to print.
If you click Current page or Pages, Word prints the page you indicate, plus the three other pages that belong on the same sheet of paper.
If you click Selection, Word prints your selection using the default page layout instead of booklet layout.
Dec 25, 2008 | Computers & Internet
HP Laserjet 3050 blank print
Have you tried a new toner cartridge? Usually blank pages are due to a missing bias voltage to, or in the cartridge.
Aug 11, 2008 | HP LaserJet 3050 All-In-One Printer
PRINT ROTATE
Hello. Try setting the casstte sitch located just inside the paper cassette, coloured blue, to the A4R setting. Let me know?
Nov 21, 2007 | Canon imageRUNNER 2000 Copier
I have blank lines through my printouts
Run the cleaning cycle. If that doesn't work, try to use an alcohol soaked swab on the print head. Some of the jets are clogged.
Oct 27, 2007 | Canon PIXMA MP130 All-In-One InkJet...
HP LaserJet 1020 Printer Logo
111 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
