Https://printcopy.info/?l=en&mod=erc&brand=Ricoh&model=Aficio%20MPC3002&code=361-02
Quoting from link above:
Ricoh Aficio MPC3002 Error Code
Code
361-02
Description
TD sensor (Vt high) error 1: C
• The Vt value of the black, magenta, cyan, or yellow TD sensor exceeds the specified value (default: 4.7V) with SP3-020-002 for twenty counts. • The [Vt - Vtref] value of the black, magenta, cyan, or yellow TD sensor exceeds the specified value (default: 5.0V) with SP3-020-001
Causes
• Black, magenta, cyan, or yellow TD sensor disconnected • Harness between TD sensor and PCDU defective • Defective TD sensor
Remedy
1. Check the black, magenta, cyan, or yellow TD sensor connector and harness between the TD sensor and PCDU for damage. 2. Check the drawer connector. 3. Replace the defective PCDU.
SOURCE: how to clean the magenta toner out of the drum unit
Change the magenta image unit,your image unit life end,
