SOURCE: car stereo cuts out
It is possible a self-protect feature may be shutting down output. Check all of your wiring, following the manufacturer's instructions exactly. Faulty wiring is a major cause of poofed audio output devices in car audio. Any short in wiring, or an open (intermittent or otherwise) can cause a problem here. Internally, bad solder connections where the output devices solder to the board could cause problems too.
SOURCE: popping noise in new stereo install
Does this only happen when you turn the stereo on? If so, it's perfectly normal. It happens when the amplifier in your stereo powers up. It's an older car with "unshielded" wiring that isn't going to be grounded properly. Oh, and to answer your question, yes, the plus (+) and minus (-) are for positive (+) and negative (-) terminals. Make sure that red is on positive and black is on negative. Reversing the polarity (installing the wires backwards) normally won't make the system stop working but it can damage your new speakers.
You also should make sure that you've connected the stereo ground. It will probably be screwed onto the back of the stereo and if there isn't a provided green wire in the bundle coming from the car than you'll just need to find a place to attach it to the car's metal chassis.
SOURCE: when i turn the volume
It seems you needs more power to maintain the level of good sound.Maybe the maximum volume is 30 - then the mininum is 15 and you can't hear any cracking sound. If you exceed 15 the minimum, as you said starting 17 - 20 you hear crackling sound .Then you reach ,what they called the "cliping level"so much distortion and crackling sound,your stereo too small to accomodate .You must add a power amplifier so crackling will gone and to fit your listening pressure...
Hope it may help you;
Regards,
VOTIT
SOURCE: jenson 4chnl amp pushing 4 6x9 jenson speakers,
Turn on thump can vary from a slight pop to a mind shattering, teeth rattling BOOM! This thump is caused by the audio circuitry stabilizing when power is applied. Most amplifiers and source units have muting circuitry that lasts a couple of seconds to allow these fluctuations to subside before passing a signal. However, if the amplifier un-mutes before the source unit or any other accessory, you better watch out. Here are some things to try if you have turn on thump.
SEE THIS LINK as well for additional information.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
SOURCE: speakers are popping
you may have a bad cord to your speaker or a bad rca cord ive had some what the same thing it turned out too be a bad groung on the rca cord
