Question about Neff U1721 Double circotherm Electric Oven
Neff u1721fan oven element has been replaced 3 times in two months
Hi i have replaced the fan oven element 3 times in two months, each the new one is installed the oven works perfectly ie set temp ok no burnt food is it that the parts i'm using are poor quality?
    Champion:
  • 249 Answers
Is it the right voltage?is the new element screwed tight when fitted?they should last alot longer than that--Ire close bye.
Posted on Nov 28, 2007
Have had 4 Neff oven elements in 2 years, why does this keep happening ? B14241 single oven element keeps blowing, grill and light are fine, any ideas please ? is it time for a new oven ?
If you are not fitting genuine
elements, this is probably the reason they are failing so quickly.
You will pay a lot more for the genuine article, but they will last a lot longer.
Also make sure the fan is working o/k, as this can cause premature element failure.
please rate my solution.
Thanks.
Feb 07, 2010 | Neff B1421 Electric Single Oven
Tip
Common heating faults with Neff B1644 single oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Neff fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Neff B1644 Electric Single Oven
Tip
Common heating faults with Neff U1421 Double oven,
on Jan 19, 2010 | Neff U1421 Double circotherm Electric Oven
My fan oven element( Neff U1452 )has been replaced
they should last 12 months minimum there could be a problem with your fan motor here is a standard fan oven check list.
You-Tube video "6QGurNvbI0Q" placeholder (do not delete)
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your oven thermostat
4, A quite common and easily overlooked answer is if your oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
Jan 13, 2010 | Neff U1452 Double circotherm plus Electric...
Need to put new bulbs and elements in fan oven
the bulbs are screw fit normally Neff fan oven element video. 1, If the fan motor . in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element .you will have to remove the back plate from inside the oven. Once removed you will see the fan and element,. if you look closely at the element .you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
Jan 12, 2010 | Ovens
Tip
Common heating faults with Neff B1421 Electric Single Oven
on Jan 19, 2010 | Neff B1421 Electric Single Oven
Tip
Common Heating faults Neff U1721 Electric Oven
on Jan 19, 2010 | Neff U1721 Double circotherm Electric Oven
No heat on bottom oven. fan running but not heating up
Jul 19, 2009 | Neff U1421 Double circotherm Electric Oven
Oven not heating up! Fan works. Grill works OK. Don't know what model it is? It's stainless with black hideaway buttons. It's a built-in Neff single oven. We had just roasted a duck, everything was...
Hi, The main problem I find with this fault is the fan element has blown. This usually cannot be seen without taking the fan cover off inside the oven. Thanks.
Jun 15, 2009 | Neff B1641 Single circotherm super...
Duco4ss main oven not heating on fan setting
put test bulb on the two wires going to fan heating element,that will tell all,if bulb lights,its the fan element that needs to be replaced!good luck!!
Dec 17, 2007 | Ovens
Neff U1721 Double circotherm Electric Oven Logo
189 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
