SOURCE: How do I change the
Step one: remove the screws to calibrate allens belt in the opposite direction clockwise allens wrench 5 / 16 "
Step two: remove the screws above the deck allens wrench 5 / 32 "
Step three: with a flat screwdriver to lift the lever of the Idler belt and remove the drive belt motor pulley. be careful
Step four: remove the rollers carefully.
Step five: Remove the deck
Step Six: Remove the philips screw that holds the spray nozzle
Step seven: now carefully remove the belt.
to install belt now repeat these steps from back to front
Once installed you must calibrate or belt slack to avoid turning the screws slide the meaning allens counterclockwise you can start with a speed 1.5Mph and increasing to 4.5Mph
any questions send me an E-mail to [email protected]
Testimonial: "Thanks!"
