Go into set up settings and reset to factory
SOURCE: Sharp Aquos LC-65D64U Picture Quality
You need to change your TV's settings and enhancements. Directly from the store and out of the box, the settings are adjusted for easiest sell in the store. That means that:
Your contrast is cranked to 100. Move this down to 50 to 60.
Your brightness may also be cranked up high. Lower it to a level nearer the middle range but not so dark as to lose detail in the shadows.
Your TV is set on "Dynamic" or "Vivid" mode. Pick "natural" or "normal" or standard.
Your sharpness is at least on, if not cranked up. Turn sharpness down or off, and the same with "Edge Enhancement" and "VSM", all to off.
Lastly, I bet you upgraded size and you are now sitting too close to the TV. Roughly, if you are sitting closer than 130 inches (about 11 foot) you might do some rearranging or save some money and get a smaller TV.
SOURCE: LC-65D64U Sharp Aquos
Call sharp back again and tell them you first want to register for aquos advantage program, which is free. By doing that your service will go much quicker with them. You then tell them that you want to get set up for service. They will have one of their authorized professionals come and fix your tv in a matter of days. If their tech cannot fix it, they will replace your tv free of charge as long as you are within your warranty.
SOURCE: Sharp 60" LCD Model LC-65D64U.
Does the blinking pause for a short time after blinking a certain number of times? Just checking whether the self-test diagnosis is able to detect the source of the problem.
SOURCE: I have a sharp Aquos
Do you get any sound at all?
I had a similar problem. I had a 52"
RCArear projection tv. It
would do this when I initially turned on the television, but then after a few
"on/off, on/off, on/off" cycles it would stay on. Eventually it
started doing it more; until finally there was a spark and that was it. The tv
was dead.The bloggers called it "the blinking green light of death" (because
of green light on the panel).The
power board is going out.ALSO holding down the Input and Menu buttons afterward will give you
some diagnostic information via 2 sets of blinking indicator lights. You may very well
have issues with capacitors on this set being that it is or very similar to the
V26 chassis. Since I have spare test lamps laying around, I would normally try
that first. If the lamp still would not stay lit, I would then suspect the
electrical chassis (capacitors). When I suspect the chassis, I can usually
verify it by pulling it out and partially disassemble it and find blown capacitors
Solution
SOURCE: What is the TV Tuner Signal Board part number for the Sharp Aquos LC-52d64U?
That the board which it have a square aluminun box at the edge of the board with a rounded bolt sticking out for inputs like ANT. input and AV inputs for like wires components inputs like multi colors like YRW,YRWGP holes for AV inputs also have HDMI hubs inputs for the high Def Pic.There are 6 HDMI inputs hubs for the tv Sharp Aquos LC-52d64U.Tvs Tuner board signal boards are also have to been known names to called as the tvs Main Logic boards and the tvs Mother boards also.U are fixing ur tv u must have to take it parts already.U can also compare the pictures between the tv Tuner signal board u are taking aparts out of the tv and the tv Tuner signal board you are buying they'll look axactly alike.The sticker of the serial numbers of the boards a few numbers in the begining on the tv Tuner signal boards should be the same also.
