Question about Baumatic 24 in. BFD60SS Free-standing Dishwasher
Dishwasher leaked water once due to an outlet block, then won't start
My Baumatic dishwasher had one accidental water leak and then it wouldn't start, it has got flashing all 4 lights in the panel. can you please advice ?
many thanks.
  • 76 Answers
It obviously has leaked water on the connections underneath, Lean the dishwasher back and see if any water comes out the bottom, then leave it standing for about a week to dry out and hopefully it should be ok.
Posted on Nov 27, 2007
Baumatic bdwi649 dishwasher leaking from underneath
what to do depends the source of the problem is. When it leaks from the water supply, then see if tightening it will help. look also for cracks or leaks. If it is the drain, check the fittings and the hose. If it is the unit itself, then you have my best wishes.
Feb 23, 2014 | Baumatic 18 in. BDW45.1 Built-in...
Dishwasher wont stop working
You will have to check if the dishwasher pump is constantly running . If the only way you can stop is by turning off the power supply, the float switch has tripped. This means ther is either water collected at the base of the dishwasher due to a leak or the float switch is faulty. ther may be an error code on the panel if this is the case.
Jul 18, 2012 | Baumatic 23 in. BDW13 Built-in Dishwasher
Baumatic starts but wont fill BKD45W model
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. Hope this helps... Please post back for any further assistance.
Daniel
Dec 10, 2010 | Baumatic 23 in. BDW8 Built-in Dishwasher
Stopped
This is a typical Anti Flood system activation. This system activates when water leaks onto the floor of the machiene due to a leak fault (pipe/hose clamp/ partly blocked pipe). The machiene automatically switches to pump out mode and stops water inlet. The anti flood system is a polystireen float / micro switch at the base of the machiene floor. Dry the floor and drectify the leak and it should work.
Jan 24, 2010 | Baumatic 23 in. BDW13 Built-in Dishwasher
Hi my whirlpool dishwasher wont stop drainning even when the start button is of
Jan 24, 2010 | Whirlpool ADG450 Slim-Line Built-in...
Dishwasher leaks at start
Is the washer not "over filling" due to the water fill vacume pipe and micro switch that shuts off the water once the correct level blocked or restricted due to fatty residue? This could also be one of the washer pipes clogged up and increasing the pressure in the fill tank.
Jan 20, 2010 | Dishwashers
BAUMATIC BFD47SS dishwasher won't start
Sounds like the water inlet solenoid valve is not opening. Not easy to get at to test, but if water is available at the hose inlet connection as you say there isn't anything else stopping water entering the wash cabinet.
Shouldn't be a lengthy repair - so I'd recommend getting a quote.
Aug 09, 2008 | Baumatic Dishwashers
BDW45.1 Baumatic Dishwasher E4 alarm
Check and clean the filters on the inlet water line (both sides). Good luck!
Sep 03, 2007 | Baumatic 18 in. BHD45 Slim-Line Built-in...
Dishwasher not draining and 3 lights are flashing
check this thread for starters http://www.fixya.com/support/t135923-dishwasher_beeping the solution to the leak would depend on where you think it is leaking from - usual areas to check are the door seal, door latch, inlet and drain hoses and where they connect, the base especially towards the back. also make sure the drain pipe the dishwasher is connected to is not blocked - sometimes leaks from in the machine can be traced to this cause. Hope this helps, post again if you find anything and hopefully we can help more :)
Dec 06, 2006 | Baumatic 24 in. BFD60SS Free-standing...
Baumatic 24 in. BFD60SS Free-standing Dishwasher Logo
234 people viewed this question
Top Baumatic Dishwashers Experts
Oloyede Monsuru
Kolbrun...
rich2481
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
