Question about HP Office Equipment & Supplies
HP Laserjet 3030 error message
Memory is low press [enter]
  • 3 more comments
  • Anonymous Feb 24, 2008
    memory is low
  • Anonymous Apr 10, 2008
    I can not fax more that 5 pages before I get a low memory error. What do I need to do?????
  • small potato Jul 12, 2008
    I cannot recieve faxes. It keeps on saying memory is low, please press enter.
    Help.
  • Anonymous Jul 29, 2008
    Memory is low when I fax more than 5 pages
  • krigerscot Dec 02, 2008
    same as above...help!
  • 66 Answers
Try clear the fax memory eventhough nothing is showing and change the quality to Standard or Text.
Posted on Dec 16, 2008
I have a hp LaserJet 3030 and I have misplaced the disk and now I cannot scan. When I press scan to it says - not setup in computer and when I press start scan it says - Waiting for pc. Please help
Access the manufacturer's web-site: http://support.hp.com
Enter '3030' and select your printer.
Click 'Software Downloads'.
Select your Operating System (Mac? Vista? 7?)
Download the device-driver.
Install the device-driver.
Scan.
Jan 23, 2011 | HP LaserJet 3030 All-In-One Printer
Hp laserjet 3030 won't copy, indicating that memory is low and to press enter. A blank page then prints.
Press cancel and then retry that job. If it still fails, try to print something else. If that job works then you are going to have to print the other job on a different printer. It is sucking up too much memory.
Sep 21, 2010 | HP LaserJet 3030 All-In-One Printer
Hp 3330 laser jet memory low error when faxing
1)Press ENTER/MENU
2)Simultaneously PRESS then RELEASE * then # to enter Developers Reset(This is a soft reset. No loss of data or configuration settings).
3) Press < or > button until the message REINIT FFS appears on the second line of the control panel.
4) Press MENU/ENTER.
5)Takes about 2.5 minutes.
6) When READY appears on display press CANCEL to exit.
Apr 02, 2010 | HP LaserJet 3330 All-In-One Printer
Hi I am getting an error message 232 on my HP Laserjet 3055 - it says on the screen that it is low on memory but I can't find where to reset the memory if this is the problem. Thank you
Perform the following to clear the fax memory:
  1. Press the menu/enter button on the control panel.
  2. Press the > button once to select Fax functions , and then press menu/enter .
  3. Press < or > to select Clear saved faxes , and then press menu/enter .
  4. Press menu/enter to confirm deletion.
As far as I know, there is no option to turn this Fax Caching option off.
Dec 15, 2009 | HP LaserJet 3055 All-In-One Printer
My hp laser jet 3030 keeps reading 79 error power on power off, pls hep with an answer
Try to perform a soft reset
1. Press MENU/ENTER.
2. Simultaneously press then release the * button and the # button to enter the Developer's
menu.
3. Press the < or > button until the message REINIT FFS appears on the second line of the
control-panel display.
4. Press MENU/ENTER.
5. The process takes approximately 2.5 minutes. During that time, the control-panel display
will change several times before returning to Ready.
6. When the Ready message appears on the control-panel display, press CANCEL to exit the
Developer's menu.
Jan 21, 2009 | HP LaserJet 3330 All-In-One Printer
HP 3030
Memory full errors occur when the printer is getting more data than it could handle. If restarting the unit does not clear it, it is a good chance that your printers Ram is malfunctioning.
Here is a site for the service manual:
you have to register, I believe it's free.
http://www.eserviceinfo.com/downloadsm/33795/HP_Laserjet%203015,%203020,%203030.html
Please remember to rate all users who assist you for free :)
Oct 04, 2008 | HP LaserJet 3030 All-In-One Printer
Hp laserjet 3030 fax
i have hp laserjet 3030. i cannot send or receive fax messages. i have checked with other machines as well. a beep sound is heard and there is no answer. my fax and phone lines are working fine.please help me as early as posible.
Sep 27, 2008 | HP LaserJet 3030 All-In-One Printer
Re; HP LaserJet 3030 Fax -low memory problem
is this plugged directly into the wall by chance, or a power strip?
Jul 28, 2008 | HP LaserJet 3030 All-In-One Printer
Sending fax error message "low memory"
Try reading these:
General fax problems
Issue Cause Solution The document stops feeding in the middle of faxing. The maximum length of a page that can be loaded is 381 mm (15 inches). Faxing of a longer page stops at 381 mm (15 inches). If no jam exists and less than one minute has elapsed, wait a moment before press Cancel . If a jam exists, remove the media. If the item is too small, it can jam inside the automatic document feeder (ADF).
(HP LaserJet 3015 all-in-one) The minimum paper size for the ADF is 74 x 105 mm (2.9 x 4 inches).
(HP LaserJet 3030 all-in-one and HP LaserJet 3380 all-in-one) The minimum page size for the ADF is 127 x 127 mm (5 x 5 inches). If a jam exists, remove the media. The fax activity logs or fax call reports are printing at inappropriate times. The fax activity log or fax call reports settings are not correct. Print a configuration report and check when the reports print. Set the appropriate log or report printing times through the control panel or the HP Toolbox. The volume for sounds that the device emits is too loud or too soft. The volume setting needs to be adjusted. Set the appropriate sound volume settings through the control panel. Fax send troubleshooting Use the information in the following table to solve problems that might occur when sending faxes: Issue Cause Solution Faxes stop during sending. The fax machine to which the fax is being sent might be malfunctioning. Try sending to another fax machine. The telephone might not be working. Do one of the following:
  • Turn up the volume on the device, and then press Fax/Send on the control panel. If a dial tone is heard, the telephone line is working.
  • Disconnect the device from the jack in the wall, and then connect a telephone to the jack. Try to make a telephone call to make sure that the telephone line is working.
A communication error might be interrupting the fax job. Change the redial-on-communication-error setting to On.
See the electronic User Guide on the CD-ROM that shipped with the product. The device is receiving faxes but is not sending them. If the device is on a PBX system, the PBX system might be generating a dial tone that the device cannot detect. Disable the detect-dial-tone setting.
See the electronic User Guide on the CD-ROM that shipped with the product. A poor telephone connection might exist. Try again later. The fax machine to which the unit is sending to might be malfunctioning. Try sending to another fax machine. The telephone line might not be working. Do one of the following:
Outgoing fax calls continue to be dialed. The device automatically redials a fax number if the redial options are set to On. Press Cancel to stop the redials while the device is dialing.
To cancel a pending fax job, see "Canceling a fax job" in the electronic Users' Guide on the product CD-ROM.
See "Changing the redial settings" in the electronic Users' Guide on the product CD-ROM. Faxes that are sent are not arriving at the receiving fax machine. The receiving fax machine might be off or might have an error condition, such as being out of paper. Call the recipient to make sure that the fax machine is on and ready to receive faxes. The originals might be incorrectly loaded. Make sure that the original documents are correctly loaded into the automatic document feeder (ADF) input tray or flatbed scanner (not available with the HP LaserJet 3015 all-in-one). A fax might be in memory because it is waiting to redial a busy number, other jobs that are ahead of it are waiting to be sent, or the fax is set up for a delayed send. If a fax job is in memory for any of these reasons, an entry for the job appears in the fax log. Print a fax activity log and check the Status column for jobs that show a Pending designation. All of the numbers of a long fax number cannot be dialed. The maximum number of digits of characters that can be entered into a fax number is 50. Try manually dialing the fax number. Faxes that are sent include a block of gray shading at the end of each page. The original may be on the flatbed scanner (HP LaserJet 3030 all-in-one and HP LaserJet 3380 all-in-one only), with the glass-fax size set incorrectly. Make sure the setting is correct. See "Changing the default glass-size setting" in the electronic Users' Guide on the product CD-ROM. Faxes that are sent have data missing from the end of each page. The original may be on the flatbed scanner (HP LaserJet 3030 all-in-one and HP LaserJet 3380 all-in-one only), with the glass-fax size set incorrectly. Make sure the setting is correct. See "Changing the default glass-size setting" in the electronic Users' Guide on the product CD-ROM.
Jul 16, 2008 | HP LaserJet 3030 All-In-One Printer
HP Laserjet 3030 printer/scanner/fax Language has
press Enter bottom
press left arrow key twice
press enter key
select the language you need then press inter
Mar 25, 2008 | HP LaserJet 3050 All-In-One Printer
1,701 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
