Question about AEG 23 in. Favorit 44070Vi Built-in Dishwasher
Favorit 44070Vi 3 short warning tones
Hi my dishwasher (Favorit 44070vi) has started emitting a continuous series of 3 short warning tones.
The manual says the anti-flood trigger has been activated and to call customer service.
I have checked the drainage pipe and filters and thay appear to be clear
What is the cause of the problem (most likely) and is there a way to fix it myself?
  • wishy washy Feb 07, 2008
    Exactly the same problem! Help please?
    Any news Have you fixed it?
  • 76 Answers
It is most likely to be the wash pump leaking underneath, the float switch lies underneath the dishwasher, if you tip it back slightly you will probably find that water will leak out, that will prove that it is leaking and it will probably work a couple of times after this but it isn't the answer i'm afraid, a wash pump is not really the sort of thing you should tackle yourself.
Posted on Nov 27, 2007
I have had a slight leek and it triggered the anti-flood alarm, i have drained all the water out and i still can not get it to reset.
Any tips
Posted on Mar 23, 2011
Dishwasher powder not dispensing
If there is no dosing detergent, following failures are possible:
- Detergent dispenser
- wiring
- electronic
Jul 05, 2014 | AEG 23 in. Favorit 44070Vi Built-in...
Favorit 40010 vi dishwasher the machine door opens during the wash except on eco 50 wash
Strange it remains closed on one stage? Usually a door that opens by itself is due to misalignment, and then gain water will leak onto the floor. If someone banged into the side of the door and moved the washer a slight bit, the locking tab under the work counter may not be in a positive position. If the tab is bent slightly up, the door may barely make contact and lock when in operation. A simple movement of the washer could pop the door open. Other than that, any electrical dysfunction would require a professional servicemans attention.
Mar 17, 2014 | AEG 23 in. Favorit 44070Vi Built-in...
Dishwasher won't drain
If you hear the motor running when it is to be draining you may have a busted pump impeller. Also locate and check the round looking cap it will move up and down by your hand pull it up if it is stuck at the bottom this is your float level it goes up and down with the water level the pump will not switch over if it is stuck on the bottom if it is stuck it is telling the dishwasher it is empty of water. and last but not least your wash timer may be out.
Apr 07, 2012 | AEG 23 in. Favorit 44070Vi Built-in...
Dishwasher cycles normally but water is not heating. Have changed heat sensor. Have checked that heating element circuit is working.
Your input panel needs to be serviced. Please try to change the AC outlet location first before attempting the service yourself. If your still experiencing problems, then remove the front panel to locate the the soldered joints behind the power button. There is a relay which may be worn and can be changed by you. You may find the area covered in rust and oxidized. If this is the case, then we have found the root cause behind your problem and will need to change out the bad part. Please reply with any question
Jan 24, 2011 | AEG 23 in. Favorit 44070Vi Built-in...
TABLET IS NOT DISSOLVING.HELP I find the undissolved tablet on the floor of the dishwasher. Tried using different cycles to no avail
Take off lower spray arm there is a spay hole underneath if its blocked the tablet gets left in the bottom. also check the filter is not split as rercycled food deposits is the cause of the blockage. short programme is not suitable for tablets,
Apr 26, 2010 | AEG 23 in. Favorit 44070Vi Built-in...
I have a aeg 43070 vi dishwasher It keeps tripping the circit breaker on the house fuse box . I have reset the leak cutout by dipping the dishwasher back and stopped the warning sound,but went for about a...
I assume you are refering to the earth leakage circuit breaker. This trips when a earth leak fault has occured. The normal cause for this could be
A) Water leaking via a pipe at the bottom comming in contact with one of the electric motors at the base of the washer.
B) A heating element has gone faulty with a electrical leak to earth.
You need to test this with a multimeter on the OHMS scale and rectify any short to earth that the meter would indicate.
Mar 21, 2010 | AEG 23 in. Favorit 44070Vi Built-in...
Favorit 43070 vi leak
I assume that this leak is from the flat tank on the side of the machiene. Any water leak to the bottom of the machiene puts the washer in ANTI FLOOD mode with the pump out motor activated. You can remove the flat tank by disconnecting the hoses to it and pulling it upwards. If you find a small leak just run it over with a hot soldering iron to melt closed the small leak. Also note that this tank has a small outlet pipe that deliberatly discharges water to the anti flood device (polystireen float / micro switch at the base of washer) in case of a fault (blocked pipe / leak etc).
Jun 07, 2009 | AEG 23 in. Favorit 44070Vi Built-in...
Antiflood system triggered-how to reset on aeg favorit 35080vi
Hello everyone. Have just fixed a problem with my aeg dishwasher thanks to this site. My anti flood switch in, so I unpluged, pulled the machine out, tilted it, wiggled the outlet hose, which I think was a little kinked and way hay it works. Thanks FIX YA. Good luck everyone. Carolyn
Feb 08, 2009 | AEG 23 in. Favorit 88070IM Built-in...
The dispenser flap doesn't open
you should check first that power is going to the dispensor at the appropiate part of the cycle. to get at the dispensor, split the door - its screwed together by screws round the periphery. dispensor is just held in by usually 6 obvious screws
Feb 27, 2007 | AEG 23 in. Favorit 44070Vi Built-in...
Open Questions:
See all AEG 23 in. Favorit 44070Vi Built-in Dishwasher Questions
AEG 23 in. Favorit 44070Vi Built-in Dishwasher Logo
1,145 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
