Contributor
- Posted on Aug 06, 2009
Re: I have an old nutone 656 bath fan and I need to...
It should be black, white, red and green. Black and white are your hot and neutral legs, green is your ground, and red is your heat leg, heat and light should be controlled on seperate switches, both 110 i believe
Does it have a light and fan?
If so you can wire it two ways but you will need two switches to seperate the fan and light. Or you can wire them together on one switch.
Are the wires dif. color and can you see where they go ( to the light socket and or fan or where the fan plugs in.)
