Question about Sony Ericsson K800i Cellular Phone
Keypad and joytick problem
From time to time my joystick does not react on "left" and "down" and at the same time both buttons left of the joystick do not work ("Select" and "Return") as well as numbers 1 and 7.
Then some time later (in few hour or few days) everything works fine again until the problem reappears.
Strangest thing is that even when joystick is not working ( left and down) in any menu or start screen, it still responds fine for scrolling down sms messages that are longer than one screen.
Can you please tell me shat is the problem?
  • Legenda Nov 27, 2007
    Sonny Ericsson K800i
  • JoeBloggs Dec 17, 2007
    Operating the Joystick on my K800i does not result in smooth operation of the cursor through the screen in all directions. Although there is always an audible click this does not result always result in movement on the screen or down menu lists.
  • 36 Answers
Hi
First of all tell me model of cellphone, so that it i can give u proper solution.
bye
sr99mobiles@yahoo.co.in
Posted on Nov 27, 2007
Logitech attack 3 joy stick does not work in my xp
The joystick should come with a USB cable to connect to the computer. Once you have connected the joystick to the computer go to your control panel and click on the Printers and Other Hardware. Next you can click on Game Controllers, next you click on add and click on how many buttons there on the joystick (Example: 4 buttons joystick w/throttle). Once you have completed these steps you want to click on the controller then click on properties to give your joytick a test run before you play a game you have.
I hope this information can help you and hope you enjoy your games that you use with your joystick.
Dec 31, 2010 | Logitech Attack 3 Joystick
Atari 2600 problem with left control plug on console
Well maybe the controller ports need to be resoldered then try soldering then with a solder iron.
Nov 21, 2009 | Atari 2600 Console
Logitech joystick controller will not work with combat arms
Alright, I am pro at making game profiles. One guy asked me this problem in logitech forums. I spent 5 hrs on research and the answer is, you cannot use logitech joystick in this game.
Check out this link and download the gamepad profile I have made, its with instructions.
http://forums.logitech.com/logitech/board/message?board.id=pcgaming&thread.id=1754
Jul 15, 2009 | Logitech Dual Action Gamepad...
MASTER RESET CODES FOR SONY ERICSSON
Here are the Master Reset codes for your phone.
Master Reset / Codes
Accessing the Service Menu - Move joystick right, press * key, move joystick left twice, press * key, move joystick left, press * key.
Checking Firmware Version - Move joystick right, press * key, move joystick left twice, press * key, move joystick left, press * key, press 1 key twice.
Show IMEI # - press * key, press # key, press 0 key, press 6 key, press # key
Manual brightness adjustment - While in camera mode, press and hold * key and move joystick to lower brightness, press and hold 0 key and move joystick to increase brightness
Quick ScreenSaver - Pressing # and * at the same time
Show screensaver and lock keypad - press * and lock keys
*#0000# - Reset language back to english
Hard Reset -Hold power for 10 seconds
May 28, 2009 | Samsung SGH-D500 Cellular Phone
Left side and upe side joystick not working
yeah it happen with sony ericsson phone joystick problem.u have joystick problem u have to show it to sony ericsson repair centre or your warranty center of mobile.and u can also use the keys your keypad keys for up down left right.thanks
Apr 27, 2009 | Sony Ericsson K510i Cellular Phone
Z525a screen comes on but stays vacant.
If you have access to a laptop computer that has an Infrared Port or Bluetooth communications, you can download your videos and picture files via either of these two methods. I use an old IBM Thinkpad 600 with IR port to download mine. You have to put your z525 phone into Infrared mode first, its kind of tricky with out seeing what you are doing. First, open your phone, press upper right (-) sign to get menu, click joystick control down 2 times then right 1 time. next press upper left (-) sign to select. next joystick right 4 times, and down 1 time. press upper left (-) sign, then joystick up 1 time. press upper left (-) 1 time. Your Infrared Port will now be turned on, and your I.R. enabled laptop can now receive the files from your phone. Close your phone, open it again, press upper right (-) , press joystick down 1 time, then left 1 time, then press the joystick center select button 2 times. Joystick right 1 time, press joystick select 1 time. press upper right (-) 1 time, joystick down 5 times, joystick right 1 time, joystick down 3 times, joystick center select 1 time. Hold the lower left corner of your phone toward the I.R. port of the laptop, it will receive the first photo file in your camera pictures file. Another possible method would be to obtain a usb connector cable for the z525 phone to connect it to your computer. Using the usb cable the computer would recognize the phone, you could click on the phone icon, under "MyComputer" and transfer the files to your hard drive. I hope this helps. -Mike
Mar 09, 2009 | Sony Ericsson Z525a Cellular Phone
Steps to forward inbox texts to email with white screen problem?
First open your phone. Press upper right (-) key to get menu. Press joystick up 1 time to get Messaging. Press joystick center select button 1 time, then down 1 time for "Inbox" (or down 3 times for email). Press center select 1 time, joystick down 1time for Inbox, center select for first message. Press upper right (-) key for "More", then joystick down 2 times to get "Forward", press center select. Press upper left (-) key to "Continue", press joystick up 1 time to get "enter email addr." Press joystick center select button, and enter the email address you want to forward the message to. After you have typed in the email address, press upper left (-) key "OK" 2 times to "Send", if you normally enter a password, type it now, press upper left (-) key for "OK" and your message will be sent. Hope this helps. -Mike
Nov 11, 2008 | Sony Ericsson Z525a Cellular Phone
Setup wizard
First open your phone, then press upper right (-) key to get to menu. press joystick down 2 times, then right 1 time, to get to Settings. Press joystick center select button, press joystick down 9 times to get to Master Reset, press center select button. Joystick down 1 time to get Reset Device, press center select, then press upper left (-) key. This will delete all user settings & data, including pictures, messages, data, sounds, games, contacts etc. The phone will be restarted. If this doesn't fix the problem, you will most likely need to replace the internal wiring harness.(Not a job even I would enjoy!) Hope this helps.
Oct 31, 2008 | Sony Ericsson Z525a Cellular Phone
Sceen is blank and i need to turn off bluetooth
Start with the Z525 closed. Next open your phone. Press the right (-) key 1 time to get Menu. Click joystick down 2 times, then joystick right 1 time, & then center joystick select button 1 time to get Settings. Click joystick left 1 time, then center select button 2 times to toggle Bluetooth OFF. Close phone & you're done. I hope this helps. -Mike
Jul 10, 2008 | Sony Ericsson Z525a Cellular Phone
Sony Ericsson K750i
need the face taken off carefully and cleaned underneath
Aug 21, 2007 | Sony Ericsson K750i Cellular Phone
Sony Ericsson K800i Cellular Phone Logo
141 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
