Question about Epson C64 InkJet Printer
Printer will not print
Hi, ive changed the ink cartridges, but it keeps coming up unrecognizing the cartridges and wont print, ive done all the cleaning processes, what do u think it could be???
  • 353 Answers
More info needed here. Are any lights on or flashing? Have you tried going through the cartidge instsallation process again (but just taking out and putting back the same cartridges when told to put in new ones)? Are the unrecognised cartridges genuine Epson or compatibles? Have you tried putting genuine Epson cartridges in (even empty ones will do) to see if they are recognised? A response to these question will permit me to give you much more specific help.
Posted on Feb 14, 2009
Unrecognized ink cartridge
The problem with generic print cartridges are they are hit and miss. Every time you replace a cartridge ideally you should replace the print head with a new one ( little metal connector on the cartridge). When using a generic cartridge the print head isn't new nor original and the printer may realise this depending on the print head condition.
another point to watch is, using generic cartridges void your printer warranty, assuming its in warranty. Generic cartridges are a quick fix but not reliable.
Mar 23, 2014 | Office Equipment & Supplies
Ive changed all the ink cartridges in the sylus dx7400, but it will not print the black ink, and the colour sheets have lines all the way through the page.ive rechecked the cartridges, but the black still...
Did you Change to Genuine Print Cartridges.????
Hello, In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, etc. These printers have a chip, that will detect if it is Generic or Genunie. When using Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Jan 21, 2010 | Epson Stylus C86 InkJet Printer
Color ink for ip1000 does not flow..??
Now put out u color cartridge and take one tissue paper or toilet paper then put ink color head to paper(soft pressure).after that see u paper are inside show three color appear in paper????(red,yellow and blue).if all have means you cartridge ok if only same or no any coming out means u color ink problem need to replaced new unit.
if got all color out better u open u printer body and check are all cable u plug in back is correct or wrong position??.second u can try go to printer preferences go to find print out in color or in gray-color and change their setting to print out in color
Sep 01, 2009 | Canon PIXMA iP1600 Printer
The red light on my epson printer wont turn off and it wont print,ive changed both ink cartridges and still no change.
Which button has the red light or which LED light? Is it flashing or steady red light? turn it off and check for any obstruction and double check if you installed ink cartridges properly.
Hope this helps
May 13, 2009 | Epson Stylus C40UX InkJet Printer
Mp470 pixma
Do you still need help with this problem?
Nov 01, 2008 | Canon PIXMA MP470 All-in-One Printer
Ink problem
You need to go to and download updates. Sometimes the all-in-ones will need them after adding new ink. Also stay away from generics inks they will cause problems. Hope this helps.
Oct 31, 2008 | HP PhotoSmart C4180 All-in-One Color...
I have had the Deskjet D4160 for over a year, now for what ever reason, the printer will not print. I have tried all of their suggestions. Restarting the computer, disconnecting the printer. I have been...
I was using the printer, wanted to change to a color ink cartridge. Upon changing, the printer made some weird sounds then didnt print. Changed back to original black ink cartridge and still wont work...Ive done everything that I can find to eliminate the problem but still wont print. Any help would be GREAT Thanks
Ink printing problem
Did you remove the plastic from the bottom ofthe cartridge, if not do so and changing from vista to xp would change that probelm.
May 13, 2008 | Epson Stylus C84 InkJet Printer
You need to put the test page that was printed into the scanner part of the printer and then press the scan/blue button. This is so the printer can calibrate the new ink. When you have done that the next time you turn on the printer a blank page will not be printed. When you next change ink you will have to repeat the above procedure.
Sep 01, 2007 | HP PSC 1315 All-In-One InkJet Printer
Epson C64 InkJet Printer Logo
325 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
